Reflctn Perfctn
Reflection Perfection
How well do they work?????? Also how do you go about refiling them to keep on filtering the water????
DFTowel said:I swear by this one, car air dries without a water spot to be seen... http://www.pwgazette.com/gardenhosefilters.htm
The Pit said:Do you use that with a pressure washer?
Bill D said:I have the same filter with the deionizing cartridge. The water here is pretty "mineral infested" so I never expect real spot free performance, just enhanced water quality.
usdm said:See now, I spoke to the folks over at PWgazette, and I was discouraged
from buying the garden setup with the DI filter. I have no idea of
the actual size of the PW systems, but I think that using
two DI filters might give similar type of results as the CR Spotless.
The Pit said:I've been looking into this too.
I had a similar conversation with pwgazette two days ago. If you combine the output of 2 DI cartridges you could get a flow rate up to 2 gpm (enough to feed my pressure washer). However, the problem (for me) lies in the size/capacity of the resin beds. My water hardness is about 20 grains/gal, and the capacity of their DI cartridge is 300 grains. Thus, I could only treat 15 gal of water per cartridge. The cost would be something like $1.80/gal. :eek Not a cheap solution. It seems like these cartridges are intended as a final stage treatment of RO water, where they would last much longer.
The CR Spotless would give you a lower operating cost for producing DI water, but I think an RO system would be even less (and you can use the RO for drinking water, coffee, etc.). I haven't made a final decision, but I'm leaning toward RO as my spot-free solution. :cool
