Do you pre rinse a very dirty wheel before applying the Sonax FE wheel cleaner? What is the optimal dwell time? I know it should not dry out but if you don't re wet it with water how long shouldn't sit on the wheels?
Hi Jeff!
I suppose you could pre-rinse the wheels, but it will cut down the effectiveness of the 'no-touch' cleaning action.
If the wheels aren't too dirty and just need a touch up a pre-rinse would help remove some grime and be more cost effective, although you are reducing the power of the product.
Dwell time can range between 1-5 minutes; the product will let you know as it works. I have had it sit on a wheel for over 10 minutes with out it drying, but on a hot day/direct sunlight/hot wheel I would be more cognizant.
Thanks Todd, the sky's opened up in NY today. Looks like I will have to wait until next weekend to try it out. Thanks for the response. Have a nice weekend.
Hi Jeff, any update on the performance? How did it end up working for you?! I hope your staying warm up there. :bigups
I use the sonax on wheels that are very dirty. My wheels usually are done with soap and water or P21S when I need more power. My brother stops buy when his RR Sport is beyond dirty and those whells have a billion spokes or so it seems. The sonax is key for the baked on dust that looks like soot from a BBQ grille.
I need it in my garage for certian jobs.
