I have a Rupes 21, Flex, Porter, Dewalt (never gets used anymore), but I use my Rupes 21 daily and rarely reach for my flex. Main reason is the force or as some may say fighting that occurs when using a forced throw machine as such and it wanting to walk or pull you. This is one big reason why I stick with my Rupes, because if I wanted to I could use it one handed with no problem and it has limited vibration compared to the flex and others. And if correction is thought to be an issue, then you may want to try a different pad or product combination. Currently and as for the past 6 months probably Ive been stuck using Megs MF cutting discs and the xtra cuts and have had amazing results. Compounds and polishes used with are as: m105, m205, FG400, SF4500 & 1500, Sonax 04-06, AMMO leveling fluid (works wonders and thanks Larry Kosilla), Rupes full line. So if you feel a rupes or any non forced machine cant get the job done, check your technique and you may find something that needs changed.
