imported_Intel486
Does anyone know a good way to test the clean power of soaps? They only thing I can tell about different soaps is how they smell and how much they sud
I seem to be able to find many articles and threads on using a DA but very few when it comes to a rotary. I have found a thread in a UK forum and the gentleman wrote a guide called "Machine Polishing by Rotary Polisher". However, he uses the M82, 83 etc. and really doesn't get into detail on how to do it. how many passes left to right, up and down, etc. And, I've read about the Zenith method (which may not be applicable to M105 or 205 since they really don't break down?).
Does anyone have suggestions for using M105/205 w/ a rotary?
Dave P
Its very much the same as a DA , overlapping 50 percent each pass ....only you want to be going much faster and letting up as you near edges.
Keep your pad flat as possible and get a good stance so the machine doesnt get you off balance
I was never taught the cross hatch on a rotary but Ive seen people do that also.
105 will dry up quickly on you and you can give it a little spray of water to revive it and work it longer. 205 you wont have that problem.
I would just do one pass and see where your at . Some soft paints thats all you need.
I would love to see more peoples advice on rotary use because honestly I got a 2 minute lesson on how to use a rotaty and always wondered if Im missing something important .
Dave P
Not allowed to link to aunother forum especially I think, so Google: 2 passes with M105/wool, no luck
Lots of posts. Pay particular attention to posts 16, 31, 42, 43.
clean your wool pad after each application, either by spurring or by using compressed air. By keeping the pad clean you get a much nicer finish....
As a good friend say's:
One of the most important things to do with your wool pads that some forget to do when buffing.
Dave,
Thanks, the surgery went fine - extremely sore, small stitches to be careful of, but releasing the tendons in the sheaths of 3 fingers and my thumb, will let me get back full use of that hand again and not have to live on Naproxen. Had the other hand done last year, and had to wait until I could afford to do this one, as it is not inexpensive.
Years of using all kinds of power tools , and probably keyboarding also as long, has finally called for the repairs.
Yes, you could try the equivalent of the Lake Country (L/C, LC) Orange pad or even their Yellow pad before you go into Purple Foam Wool if you want.
As another option, 3M makes a very small purple foam pad that is very aggressive and even comes in as small as a 3" pad, which is great if you just want to touch a very small area of damage, and not hit surrounding paint.. Of course, it would require a backing plate that size too, etc...
Im trying to remember - someone else on this forum has a beautiful red dodge truck and has posted pics before of it - who is that ?????
Angelo -- does this fine company have any clients in Baltimore area that might be able to check in with Dave here ???
You are doing great, Dave! Glad that you are taking your time and learning all you can on the way.. There are very few things that can substitute for the feeling you will get when you have your truck and your Rogue all detailed out, blinding, clear, no swirls paint, and stunning gloss and protection, and you look back and say - wow, I did that myself !!!![]()
This technology alone has made huge advances forward just in the last year even, (Meguiars D300 series compounds, microfiberpads for D/A, Optimum Clear Coat, etc.), and it looks like these are winners based on what I read here and other forums.
Hopefully, we can find some people out your way that can check in with you!
Hope you continue to enjoy your stay here!
Dan F
