mjlinane
My name is Mike
Review: Chemical Guys Hybrid V7
Introduction:
I mentioned in one of my review responses that I started off mainly using Chemical Guys products (this was before ACC picked up the line - before I knew about ACC even). They are an interesting outfit and, on one order, they tossed in a complementary bottle Hybrid V7, unsolicited.
Thanks to Corey again for providing the format.
Product Claims:
From CG website -
"Hybrid V7- Optical Select – High Gloss Spray Sealant
When selecting to design a new sprayable sealant and hybrid gloss enhancer spray detailer we decided to work from the ground up. We wanted something that was unthinkable, a product that would vanish into the finish instantly. A durable sealant that would disappear into the surface in a single wipe delivering long lasting superior optical-clarity and a high-shine slick finish. Hybrid V7 has undergone extensive testing to deliver a superior high gloss, wet shine, deep, reflective finish that takes any surface, wax or base sealant to the next level. Hybrid V7 works at a nano-spec level and bonds to surfaces instantly while its hybrid fast-flash technology virtually disappears into your finish leaving a durable streak-free high gloss, slick, non-stick finish.
Three years in the making and it is finally here! We asked our long time friends and customers to test over 53 different new formulation in an effort to create a product unlike any other. We shipped samples all over the world from Thailand and China to the UK and even Romania. We wanted your feedback ! What we got back was nothing short of amazing, out of 53 different samples that went out to over 300 different testers, virtually everyone came back raving and ranting about the same sample #23771-V7. Thanks to all the amazing friends and clients world wide that made the new Hybrid V7 what it is!
We asked:
Which product brought out the most shine?
Which products yielded the biggest change to the surface?
Which product did you enjoy using the most?
Which product was the easiest to use?
Over a 16 month trial and test period which product held up the best?
Out of your arsenal which product did you reach for the most?
Which product worked best during cold vs. hot weather?
Which one did you like the best overall?
We took the feedback and are proud to finally release Hybrid V7- Optical Select – High Gloss Spray Sealant
Hybrid V7- Optical Select uses state of the art optical gloss enhancers and a process of RBA- Rapid Bond Acceleration to deliver a transparent high gloss finish combined with a durable protective coating for paint, glass and virtually all exterior surfaces.. Utilizing a proprietary bonding system Hybrid V7 can also be used in detailing and maintaining rubber and plastic exterior surfaces delivering a durable and invisible UV coating that 100% non-greasy or 'waxy'."
Details:
1.- Packaging: Plastic Bottle and Trigger Sprayer
2.- Directions: Clearly labeled
3.- Viscosity: About the same as water
4.- Color: Orange
5.- Scent: Orange sherbet
6.- Price at time of review: 16oz = N/A from ACC
7.- Manufacturer: Chemical Guys
9.- Made in: California
Product
Other Products Used:
Short nap MF
Preparation:
It is a quick detailer so it depends on what you are trying to do with it. I never apply QDs except to freshly washed paint - but that's me.
It is also a spray sealant so, in this case, a clean car is a good place to start.
Application:
This seems to have changed since I got mine. Was recommended to spray on MF and then apply to paint. This is how I still apply it. However, recent CG videos show them spraying directly on the paint and wiping with an MF, turning and buffing - much like any standard QD or spray sealant.
I prefer my method. I do not know if the formula has changed in the interim. The packaging has.
Observations:
Wonderful smell. Leaves a glossy, slick finish. Melts into the paint leaving no streaks. A delight to use.
Love it for the final wipedown when applied over other sealants. I have applied as a standalone LSP on silver & white cars and on one black one and it was stunning.
Interestingly, one of my favorite applications on my personal car is on the hard plastic trim around the mirrors and on the B-pillars. The car is only a year old so they are in really good (perfect) shape and are a textured, semi-glossy black. CG Hybrid V7 melts into those as well but doesn't change the gloss level. It does obviously add protection as they bead like mad.
Does it meet its claims, yes.
Comparisons:
I believe V7 was created in response to products like Optimum Opti-Seal and UPGP (don't have this one). All (when applied as I do) are WOWA (Wipe On Walk Away) products. I truly like Opti-Seal and is used even more sparingly than V7 but I really prefer applying V7. It is just more natural and seemingly easier. Smells better, too.
Comparing to Wolfgang DGSS, I prefer WOWA to WOWO (Wipe On Wipe Off). I like the gloss and durability of Wolfgang and use it a lot on wheels (looks very good on paint, too). The cinnamon scent is quite nice, too.
Pros:
1.- Cleans (lightly) and protects in one step
2.- Cost effective in the gallon size
3.- Fantastic smell
4.- Leaves a slick, glossy finish on paint
5.- No streaking, melts into the paint.
1.- Durability. Seems to last a goodly while but durability testing is not really something I care to do. Too many products to try.
Cons:
1.- None I've found.
Final Observations and Summary:
I originally wasn't going to post this review because ACC, for some unfathomable reason (to me, anyway), doesn't currently carry CG Hybrid V7. Forum members encouraged me to do so anyway (open forum and all) and hopefully ACC will soon pick it up.
This is my favorite spray sealant. I also think the fates agree with this because every time I try to order a different spray sealant from ACC (EF High Gloss Acrylic Shield and, yesterday, a gallon of BF DGSS), the order is taken and then cancelled the next day!
I don't use V7 as a QD (I don't really use QDs as QDs), but I do think the mild cleaning ability makes it perfect for the final wipedown. It removes streaks and adds that little pop. On its own, it seems to have decent durability and works exceptionally well on new plastic trim.
Comments and questions are encouraged. Thanks for viewing!
Introduction:
Product Claims:
From CG website -
We asked:
Details:
4.- Color: Orange
Product
Short nap MF
Preparation:
Application:
Observations:
Comparisons:
Pros:
3.- Fantastic smell
Cons:
