Review - BLACKFIRE Interior Protectant (Updated Version)
Angus
AspiringProductSpecialist
New and improved - BLACKFIRE Interior Protectant!
From PBMG copy for the updated BLACKFIRE Interior protectant:
New formula lasts longer and dries quicker. A fresh new tropical fragrance will make you feel like you're relaxing on the beach every time you enter your vehicle!
Revolutionary! A leather conditioner and vinyl protectant in one bottle!
BLACKFIRE Interior Protectant with Polycharger is the only product you need to maintain the look and feel of leather and soft vinyl upholstery. This 100% water based protectant uses micro-engineered polymers that are readily accepted by leather and soft vinyl. BLACKFIRE Interior Protectant contains no oils, silicones, or petroleum distillates. It leaves a deep, satin, natural-looking finish on interior auto surfaces.
Directions:
Prior to application, all interior surfaces are cleaned with DP’s Total Interior Cleaner.
Per the instructions:
1. Shake well - Check.
2. Spray directly on the surface or spray a microfiber applicator pad and wipe areas to avoid overspray on glass. -Check.
In order to avoid overspray, I always spray products onto my applicator vs. directly onto the vehicle's surface. Doing so helps control where you want the product to go and more importantly not to go. Also it helps at preventing an uneven application by avoid high spots created by the spot sprayed.
BF IP has a white milky color and I love the new tropical smell. The old version didn’t have any noticeable odor at all.
The new version is super easy to apply a nice even layer:
3. Buff any remaining residue with a clean, dry microfiber towel - Check
After a very light buff:
Next up the shift boot:
4. For leather surfaces, allow to penetrate for 2-3 minutes before wiping off. - Check
(Freshly applied on the left - after a few minutes and a light buff on the right)
Observed differences between previous BF IP and the updated version (labeled V1 and V2 respectively)
Since I had a bottle of the original BF IP in my detailing supplies, I decided to see if I could tell a difference between the two versions.
Using the passenger's side door as my test bed: the left half of the trim (door hinge to middle) received V2 and the right half (middle to door handle) received V1.
Top photo, no dressing, middle photo was taken from the V2 end, and the bottom photo was taken from the V1:
Now I’m point at the divide between the two versions:
Can you see the higher amount of gloss on the right side vs the lower sheen found on the left?
If not, I’ll zoom in:
How about now?
If it’s still not obvious I’ll zoom in a little further:
So hopefully by now my over exaggeration of photos has allowed you to plainly see V1 produced a dark “wet” look with a higher gloss verses V2’s nice dark low sheen.
I strongly prefer the appearance of the new version and in all honesty the only reason I had some of the old version left over was I didn’t care for the higher gloss it produced.
Conclusion
Overall I really like the new version of BLACKFIRE Interior Protectant. It smells great, is easy to use, and as demonstrated it leaves behind a nice non-greasy low satin sheen.
If you’re in the market for a new interior protectant don’t hesitate to check BLACKFIRE Interior Protectant! If you have a bottle of the old version - make someone else happy and give it away (I did)! Cause you’re going to like the new version even more!!!
great review and looks like nice stuff. Might have to try it someday when I'm in need of more interior protectant.
Thanks for the write up. I may give this stuff a shot after my Detailers interior protectant runs out
nice review and comparison
I still have a full bottle of v1, really like it but I switched to a clean/protect product for all the cars I work on
saved the bf for my own car
Great pics and review Angus :bigups
Thanks, Paul!
Oh man, I love me some DP IP. Last year I did a write up comparing the prior version of BF IP and gave DP IP the advantage:
http://www.autopia.org/forums/detai...s-pro-series-interior-surface-protectant.html
Now with the new version, it would be a very close showdown... Hmmm... A revisit to that review may be in-order. :)
nice review and comparison. I still have a full bottle of v1, really like it but I switched to a clean/protect product for all the cars I work on saved the bf for my own car
Thank you! Time = $$$ I don't blame you at all for using an AIO interior product on customers cars and keeping the good stuff for yourself. :bigups
Great review. Love the side by side comparison. Thanks
Thanks, Ron!
Very nice review. The end result is subtle but when seen side by side obvious.
Thanks, Gearhead!! In person the results were plain as day, but as you know, they aren't always easy to capture in photos. Glad I was able to share it with you guys.
