Vincent231
Anyone have any thoughts on the best way to get rid of them? They're around the edges of a 1/8" circular paint touch-up, left over from sanding the primer. I have 1000, 1500, and 2000 grade 3M wetordry papers, but now that the 800 grit marks are there, I don't know if using progressively higher grades will only make things worse, or if I should try to get the 800 marks out straight away with 3M Perfect-It II rubbing compound followed by 3M Swirlmark Remover. The paint is metallic silver, and if I run my finger over the white dull spot caused by the 800 grit paper, the spot momentarily disappears (especially with a little moisture) before reappearing, so I'm hoping the marring isn't *too* deep.
