mjlinane
My name is Mike
Quick Review: Dodo Juice Low on Eau
Introduction:
Here in central Texas, it is another one of those difficult times of the year to detail. Not because of the heat (dc - I lived in SD for 6 years, it isn't hot there - at any time!
), but because the trees are shedding. More than 10 seconds outside and your car is covered with leaves and stuff raining down. Trying a 2BM will fill your buckets with same - and not transferred from the car! So I've taken to a hybrid method: foam the car, pressure rinse it off, pull into the garage, air dry/leaf blow with MetroVac and then do the Garry Dean Wash Method (GDWM) rinseless wash. Did my car this morning and randomly pulled Dodo Juice Low on Eau as the rinseless wash du jur.
Thanks again to Corey for the format.
Product
Product Claims:
From Autopia Car Care site - Dodo Juice Low on EAU Rinseless Wash 250 ml.
"Ban the hosepipe! Bring on the rinseless revolution!
Ultra slick rinseless wash with gloss agents
Save water and increase shine
Highly concentrated formula
Eau is the French word for water. Dodo Juice Low On Eau is a highly lubricated non-foaming car wash, designed to clean lightly soiled surfaces with out the need for a final rinse. This product will clean your ride and impart a Dodo Juice shine while saving water over a traditional wash. Use Dodo Juice Low On Eau Rinseless Wash on slightly soiled vehicles.
When you first open your bottle of Dodo Juice Low On Eau Rinseless Wash the fresh pineapple scent will take you a journey to Mauritus, the home and industrial epicenter of Dodo Juice. Little men in orange lab coats scurry about hand crafting superior car care products. As your add Low On Eau to your wash bucket and experience this products performance you will be glad to be back to reality. Dodo Juice Low On Eau is a great performing rinseless wash.
Add 3 capfuls of Dodo Juice Low On Eau Rinseless Wash per gallon of water in your wash bucket. For best results use two buckets, each with a Grit Guard ® insert at the bottom. Rinse your wash sponge or mitt in the second bucket after each panel. Wash and dry one panel at a time, starting with the top sections of the vehicle and working downward until the entire vehicle is clean and shiny. For more protection and gloss, lightly mist each panel with Dodo Juice Red Mist Tropical Protection Detailer during the final drying."
Details:
1.- Packaging: Plastic Bottle
2.- Directions: Clearly labeled
3.- Viscosity: About the same as water
4.- Color: Pale yellow/orange
5.- Scent: Pineapple
6.- Price at time of review: 250ml = $ 14.99
7.- Manufacturer: Dodo Juice
9.- Made in: England?
Other Products Used:
Pump sprayer (with ONR v2 because I was too lazy to empty it)
1x 2.5gal pail
1x 660 GSM MF (wash - car was pretty clean)
1x CG Shaggy Fur Ball MF (pre-drying)
1x 16x24 WW MF (final dry)
Preparation:
Instructions call for 200:1 dilution so I used 0.75oz in a gallon. I dumped my 660 GSM MF and Fur Ball in the pail and doused them with the Dodo Juice Low on Eau (LOE) mixture. Normally, I would have filled my sprayer with LOE but it is ragweed season, too, and wasn't feeling it.
Foamed the car with CG Honeydew Snow Foam and pressure rinsed off. Pulled into the garage and blew off the new tree crap that fell on it in the time it took to pull it in.
Application:
I employed the aforementioned GDWM. Pre-sprayed the horizontal surfaces. Lightly wrung out the 660 GSM MF and gently wiped in 1 direction (snake pattern) across all horizontal surfaces. Pulled out the Fur Ball and tightly wrung out. Pre-dried with Fur Ball and final dried with WW. Repeat on vertical panels.
Observations:
Very pleasant scent. Car was pretty clean so can't tell about the cleaning ability. (Have used it before and it is on par with the other rinseless products.) Nicely slick. Gorgeous finish. Kind of expensive.
Afters
Used this much
Does it meet its claims? Yes.
Pros:
1.- Cleans very well
2.- Leaves no staining on MF
3.- Pleasant smell
4.- Beautiful finish.
Cons:
1.- Not as cost effective as other rinseless products.
Final Observations and Summary:
Wasn't planning on writing this review this morning but was so pleased with the resulting finish I felt compelled to. This isn't the most cost effective rinseless product on the market, but with the GDWM, the little you get will go a long way.
Comments and questions are encouraged. Thanks for viewing!
Introduction:
Product
Product Claims:
Details:
1x 2.5gal pail
Preparation:
Application:
Observations:
Afters
Used this much
Pros:
3.- Pleasant smell
Cons:
