i applied mine with my gg da 6" using Griots Garage 6 Inch Glass Polishing Pads, Set of 3 with excellent results. i believe a standard white polishing pad would be ok.
Jeff, any luck with the application?
You can apply G4 either ways you like. I wanted to test it by hand.
The weather was a washout here this weekend and I did not. I did however get to see the isane beading of the EXO. I will post a pic if I get a good one. Beads of rain on pearl white with a crappy iPhone camera is not to easy.
