Proper way of using 6.5" Cross Groove Foam Pads?
dennn
Hi guys,
Cobra Cross Groove™ 6.5 Inch Flex Foam Buffing Pads,cobra foam polishing pads,foam buffer pads,dual action pads,cross groove pads,waffle pads
So... I bought three of these foam pads from Autogeek to try them out. I bought the white one for polishing.
Why did I buy them? I just have the habbit of buying different products to try out on my cars. I have used this product with SwirlX, Ultimate Compound, and M205, on either the rotary or the DA XP.
While using these pads, I realize that they skip and jump like crazy. Unlike the flat pads, these pads don't stay planted to the vehicle's surface. They are a pain to work with on a completely flat panel. In order to keep these pads from skipping and jumping across the body panel, I had to apply roughly 25-40lbs of pressure on the pad. And Putting that much pressure onto the pad is not a solution because doing so would simply defeat the purpose of the refining polishing procss, as well as induce fatigue. Needless to say, the skipping is caused by the grooved sections.
So did I just waste $35 on these pads? I don't know if there is a proper method to using this pad, but I can't think of any other ways to use them. These pads are utterly unuseable and I am not impressed with them.
I found out why I was experiencing so much skipping with this pad.
I was using a 6" Backing plate, which didn't allow me to compress my hand pressure onto the pad. This particular white "German" polishing foam is a little stiffer than the LC White and Softbuff 2.0 counterparts, so in order to adequately put pressure on the pad, I need a smaller 5" backing plate.
Using the 5" backing plate, whic is recommended by both Autogeek and ADS, seems to allow this pad to work nicely. It still isn't the best the pad for optimal comfort compared to a completely flat type design, but at least using it with a 5" backing plate makes the pad useable. With a 6" pad, I was unable to adequately compress the foam to make it sit flat on the paint surface.
