Product recommendations for carpet dirt, oil, and grease
jmeuphonium
I did a search on how to clean oil and grease picked up by shoes in parking lots and ordinary dirt. It looks like I need to do the following
1) start with a solvent
2) then an alkaline based cleaner (brushing lighty after applying each)
3) let this sit for 20 mins or so
4) lightyly apply water and use a shopvac to dry it out
5) repeat applying water and vacuuming several times
6) place a fan on the spot to try to dry it within 4-6 hours
I hope this is correct :)
Now to my questions. What actual products do you all use for this? Do you just you something like paint thinner or acetone as a solvent, or something specific for the auto industry? What kind of akaline cleaner do you use?
I'd really like something that I could buy at Autozone, O'Reilly's, Walmart, ect...
Thanks!!!!!
For oil and grease on floor mats, I have had pretty good luck with citrus based hand cleaner (the kind you get at autozone for cleaning your hands after an oil change).
Put a big glob on the stain, and rub it in with a brush. Follow with hot water and the shop vac to extract all of the mess.
An excellent solvent is carried by True Value Hardware stores called Carbo-sol, under the "Sunnyside" label. Perfect for your applicatin.
