Preachers Sheets
I used to use these tiny pads:
http://www.properautocare.com/porcabac.html
My order was messed up and in the end I got these pads:
http://www.properautocare.com/adfoampadfor.html
Off the bat I noticed the Advanced pads are larger (duh), it allows me to detail more of an area in a shorter amount of time, not a small time increase; it really cuts down my detailing time.
The velcro backing is 100 times better than the regular pads I am used to, I used to use the old pads until they were literally smoking!!! After 3 of those incidents, a 1/4 inch section of the velcro backing all the way around the pad would wrinkle up. The pads were junk.
The pad doesn't have a edge like a wall, the edge sort of wraps around the backing plate so you don't have to worry about hitting the backing plate up against your paint. You can use the edge of the pad to get into tight little areas that you would normally have to do by hand.
All I have to say is GET THE ADVANCED PADS!!!!
