I received a nice surprise from Ray –It was a bottle of Polish Angel Viking Coat and Escalate Lotion.
THANK YOU RAY!
Marketing shot below:
Stuff comes wrapped like a present
So I started early but the sun was up so I pulled out something I have not used yet the CR spotless.
Here are a very few before shots. It was not too dirty so the before shots will be abbreviated
Wheels cleaned with Sonax FE and various brushes.
Car was washed with 2BM with Citrus APC and Car wash.
Decontaminated with Iron X and a Nano Skin Pad
Rewashed and dried with an Uber drying towel
Water hugger areas blown dry with master blaster.
It’s hard to catch marring on a pearl white car but here was the worst of it
I was told Polish Angel products don’t stain trim nor do they dust. As a result I did not tape and I had zero issues. I would only tape trim harmed by the pad. On this car the trim is all chrome and there is little of it so no tape was used.
Finish after Escalate Lotion.
This is a paint cleaner, fine polish and primer for the Viking coat. While not absolutely necessary for proper bonding, it replaced the finish polish I usually use to clean up any imperfections. I used the 3” Rupes with a yellow pad for the entire car. I tried the PO5RD on one panel and did not get more gloss so I stopped. The Escalate has a primer to accept the Viking coat so I skipped the IPA wipe down per Polish Angel USA. (On the one panel I did with POP85RD I wiped with IPA)
I have been finding I like the 3” simply because it allows me to chop up panels into flat spaces easier than the Rupes 15. I guess the hood would be fine for the 15 but I am to lazy to pull it out for one panel. If I did this professionally I would look to save time but since this is hopefully a once every 2 years / per car deal it’s not a big deal.
This next picture is after the first coat was applied, let sit for 45 minutes and buffed off. This is applied using a black pad and a DA. Love this application. Fast, and you can see this product almost like an old school wax and sealant but it’s a coating. Make getting every bit of paint covered a piece of cake.
After a 2 hours cure period I hand applied the last coat of Viking Coat with the included applicator. I let it sit for 45 minutes and then buffed it off. If comes of super easy and there is zero fear of high spots for letting it sit a little longer. The 2nd coat stat closer to 1 hour and came right off.
Finished Shots
Later in the day fully (cured 3-5 hours)
Video before I passed out at the end of a really long day. This really shows the pearl coat in detail.
Click picture to play video
My opinion of the Polish Angel Escalate and Viking Coat is as follows. Super easy application and removal. Both products do what they claim to do. The escalate is easy to work with, does not dry out and gives enough correction to fix minor marring. It finishes as well as a finishing polish. I used it on my B pillars that are black plastic and they looked good to me. I ended up visiting with another polish Angel Connoisseur and he hit them with the PA finish polish and it took them to near perfect level from very excellent. On the pear white it did not make a difference but on dark colors it very well may make a difference.
The Viking Coat is a very good looking coating on the car. It looks like a beauty wax and if it is as protective as a coating like EXO or Opticoat Gloss Coat it would be amazing for someone looking for a warm shine instead of a crisp sealant/coating look.
I will update you in durability. I currently have 22PLE, EVO v2, Gloss Coat and PA Viking Coat all applied within 4 weeks of each other. I will be able to compare them as they age.
Here is a Viking Coat beading pic from a day or two after application
Thanks for looking, feedback always appreciated.
THANK YOU RAY!
Finished Shots
