Pet odor removal - urine and wet dog
Jpostal
Excellence Auto Gallery
About a month ago I bought a van through an online auction for my used car lot. When the van was delivered I nearly fell over...it was the nastiest, rankest smelling vehicle I have ever come across. Pet hair was everywhere and there was the stench of what I can only guess to be old dog pee.
After a thorough vacuum and wipe down I shampooed the carpet and seats 2 or 3 times which improved the smell by maybe 20%.
Next I did an ozone shock treatment (Corona discharge) which did very little to help the situation.
Next I did a DrivePur treatment. This helped to eliminate the wet dog/dander/pet hair smell. At this point the seats and panels smell almost 100%.
The lingering problem is the bad smell of what I am assuming is urine in the carpets. For the past 24 hours I have been doing an enzyme treatment (keeping the carpet damp) on the problem areas between the front and middle row seats. Having never used enzyme before I'm not exactly sure what to expect and how long to wait. After 24 hours I dont notice any improvement in smell, but I did run into something that I thought was interesting. After saturating the carpet I placed a new, damp terry cloth towel over the area to keep it from drying out too fast. When I checked on it 30 minutes later the once clean towel was covered in brown spots...
So after extracting 3 times, ozone shock treatment, DrivePur, and enzyme treatment I still have an odor problem.
At this point I dont know what to do. In the condition it is in the van is almost un-sellable. I did a little research online and some places suggest using a mild bleach solution to disinfect and deodorize the area so I'm thinking that after the enzyme treatment is done I will extract the area again, treat with bleach, and rinse clean.
Any other suggestions?
Un-Duz-It - is a concentrated, professional quality formula that utilizes enzymes to digest the bacteria, it utilizes bio-enzymes – the complex organic substances formed in the living cells of plants and animals – as catalysts for the decomposition of organic-related odours and stains. -It is effective on all water-safe surfaces including carpets, upholstery, plastic, clothing, vinyl and more. TOTL
Would this provide better results than the enzyme product I have already used? Here is the MSDS for the enzyme cleaner I am using...
http://www.cleananswers.ca/wp-content/uploads/2010/03/ENZYME-D.pdf
I don't know if will help in your situation, but I had a customer recently with very bad lingering cat pee odors, which is worse than dog pee. She asked if I could just spray something in there to see if it would help. I had some of the Chemical Guys Offensive Odor Eliminator concentrate, sprayed everything down with the undiluted concentrate and she said within 3 days the smell was gone. Your situation looks like it's way worse, but the stuff is cheap so it couldn't hurt to give it a try.
Did you try pulling the carpet it to see if there's urine soaked into the padding? You may end up having to pull the carpet out a give it a good pressure washing or something.
I havent pulled up the carpet and I really dont want to, but the way things are going it looks like I might have too. I'm going to do a final enzyme treatment followed up by the bleach. The problem is that the pee likely seeped through into the padding and spread out.
