xtremekustomz
I've finally gotten started working on my truck again. My initial plan was to go with a simple solid color but that changed. I figured if I wanted some more side work it would be beneficial to have something kinda flashy that would catch the eye and possibly start a conversation. I have some issues with the black basecoat that is on it right now starting to release from the primer below so it's a full strip on this one. I'm doing a metallic red on the top with a silver/grey pinstripe and white on the bottom. The pinstripe and both colors will flow through the door jambs and partially through the fenders. 3 coats of clear will be applied and the next weekend I will flow coat 3 more coats. Here is what I have done so far:
Epoxy Primer:
2k Primer:
Stripping the doors down I found a good bit of damage so I purchased a 3rd door, passenger door and an HD hood.
3rd door damage:
Lower rear cab repair:
Evercoat Everglass:
Evercoat Rage Gold and Metal Glaze:
Jambs:
Fender:
Epoxy Primer:
2k Primer:
3rd door damage:
Evercoat Everglass:
Jambs:
Fender:
