Hello,
I'm currently using a PC 7335 with a 6" backing plate and 6" LCM pads. I'm literally tearing through the 6" white pad and have already damaged the 6" yellow pad. As I use DACP on the car, I see blue bits and pieces flinging from the pads.
I read some threads today and found out I'm using the wrong size backing plate for the 6" pads. I only run into problems with the white and yellow pads though. The black and red pads aren't being damaged I think because I'm running the PC at lower speeds with them.
So for the next time I detail the car, I was wondering if it would be best to just buy yellow and white 7" LCM pads or buy a 5" backing and 6" yellow and white pads to compensate for the ones I damaged.
Any suggestions would be most appreciated ;-)
