My Opti-Seal arrived Tuesday and I was able to put one application on the Montana today.
I used a Viking Handi-Grip applicator.
A short spray to "prime" the applicator and it went on quite easily. I applied the product to the applicator, then wiped it on the paint.
It took very little product and I probably used more this time than I will the next time. The Montana is white and it wasn't real easy to see where I had been.
It probably took 10 minutes to do the van and I didn't hurry at all. About the same as DG Aqua Wax.
After the initial application, I saw little or no difference from the DG105/AW that had been on the vehicle for about 3 weeks.
After a few hours, I think it might have a little more pop. (If white has pop.
It seems to dry pretty quickly and the concern someone had about dust or pollen getting in it before it dried would seem to be no problem.
As I said, I used it on a white vehicle with virtually no rock chips so I don't really know if the stuff will be clear in the chips.
I hope to polish the GP tomorrow and use the OS on it. It also has very few rock chips, but it is red and I should be able to tell if the OS is invisible after it dries.
My guess is that it will be.
Charles
Charles
