imported_garyo1
When you use ONR as a clay lube what is the dilution ratio?
Thanks
Thanks
New Skool said:I was actually told in an email from David that ONR can be mixed at 8oz per gallon of water as a spray and wipe product and a clay lube.
john1r said:Sorry if this is a dumb question, but as long as I stick with the ratio of 2 oz of ONR to 1 gallon of water, can I modify it to fit whatever spray bottle I have? For example, I don't need a whole gallon of clay lubricant, so can I just use 1 oz of ONR to 1/2 gallon of water? Or even 1/2 oz of ONR to 1/4 gallon of water? Or is it really best to have those 2 oz of ONR in there?
Thanks!
swan said:Yes you can.
Another question regarding ONR as clay lube. Anyone else notice how when you first mix it, the water turns blue but turns almost clear after a while? Thought I picked up the wrong bottle the first few times.
Why does it do this?
