Ok, i have a problem with swirls on truck (its black). the truck never really had any swirls in i first bought it used but recently it has been swirling pretty bad.i have changed my washing habbits hoping that is the problem, but first i need to get rid of the swirls. I have tried meguiars swirl remover and then a profesional swirl remover from a local detail shop. Both products reduce it, but you can still see the swirls pretty bad in sun light. I Have a porter cable da polisher and i think i need to try the DACP. Im only concerned about using the DACP because im afraid of going through the paint, will the dacp do that? I was also told that after i use the dacp to use a swirl remover, then a glaze, and then a finishing wax. Then they told me after i get it to where i want to use a non abrasive wax with a hard shell to prevent the swirls from coming back. Im planning on buying the DACP tommorow along with a non abresavie hard shell wax. so any tips would be appreciated
thanks
thanks
