The Driver
Detailers Workshop
Installed the new Lithium battery, Anti-Gravity Rs-30, WOW. I never thought I`d say that about a battery but the weight and the tech is pretty cool. I can tell the rear is a bit lighter through the tight twists. The Re-Start function is pretty crazy as well.
Pros
Saved 41 lbs and removed it off/PAST the rear axel
Nice anti-theft feature (Battery has an on off button + battery gauge)
Battery has an Auto-shut off when it gets to low so you can still start (Re-start technology)
No AGM gas venting, No lead or Acid
Cons
Price at 680$ it`s not cheap but removing over 40lbs is extremely tough to do on the R
Not as many AH @ 30 AH vs 85 you do have to watch parasitic draw
CCA isn`t specified, rated at 1200 CA, base on braille and others my conservative -30 degree estimate is around 750-800cca, my Bosch was/is 850cca
rs30 by Joseph Cipriano
Pros
Cons
