My washing regimen and foam gun use
Striker
Active member
I use the two bucket method with a foam gun on garden hose.
I start off by:
-Rinse
-Foam gun with whatever soap I have laying around in the gun (armour all now)
-Rinse again
-Proceed with two wash bucket method and dry.
My question is, am I wasting time here since I`m just letting the suds from the foam gun sit for a bit then I rinse it off and proceed to do the hand wash. I guess I`m not too sure what the proper way is to wash with a foam gun here!
Thoughts ?
Re: My washing regime and foam gun use
I`m sure there are other options but your technique is exactly what I do.
I let the foam dwell for awhile to get off any lose crud. Then rinse and do a 2 bucket wash.
I foam dry with my awesome IK foamer 9, I don`t pre rinse... I feel the soap becomes too diluted if I pre rinse, and if I do pre rinse, its because there are CHUNKS of "sh_T" on that car. lol. Not sure if it truly makes a difference.
I foam the car, let it dwell, rinse then foam while running the mitt over the paint. Haven`t touched buckets in years
This is what I was thinking.
Why can`t I hit it with the foam gun. Rinse. Foam again. And then hit it with my sponge and rinse ?
I don`t see any reason why not. Bear in mind the way I do it, which I learned from Accumulator, uses a lot of soap and water though.
I don`t pre-foam anymore, didn`t find any benefits that i could notice unless I plan on scrubbing something(rubber trim etc but I just spray APC and that does the trick). Only time I use the foam gun is to do the Mike Phillips Aggressive wash method prior to polishing a car or if I want to be extra careful I`ll do the foaming and mitt gliding simultaneously as mentioned above . I used the technique to maintain my black SUV years ago and it worked like a charm every time, it is time consuming since i do it veeery gently.
Did you get the small foamer as well? Curious if it blows away the Kwazar, I need to place my order for the iK today!
Kwazar foamer = foam master
IK foamer = foam cannon
I love them, more than any foamer i`ve ever used. lol
I like foaming the car because in some situations, it just looks cool, I never really notice a real good benefit to it, but its just a preliminary rinse for me, I feel that some soap dwelling can loosen or soften some caked on road debris.
I haven`t used a foam gun or even a traditional bucket wash in quite some time. Forget the foam canon. Wastes too much water and is a hassle. ONR weekly washes have taken over. Much more eco friendly for us So Cal drought folks.
But this is what I do when I used the foam gun.
Rinse
Foam
1 bucket wash
Rinse
Dry with DP car Dryer
Seems like I`m just wasting time and not doing it right with my rinse-foam-rinse method.
There is no wrong way to wash a car, unless you do it like the dealership.
The Guz likes to save water.
Others like to use water.
I like somewhere in between...
Don`t let us tell you how to wash your car man, I am sure you know what you`re doing and have been keeping your car in top shape.
Yup. Doing my part. Also neighbors reporting neighbors for a hefty fine is not a good thing.
Keeping the car marring free is what matters
Exactly this.
Oh it`s mar free. All three black cars are. I was just wondering if I am utilizing the foam gun properly or not :)
It would seem like a waste if I wasn`t.
I`m sure Accumulator will chime in here eventually. To the best of my knowledge he was the first member to widely use a foam gun.
Rinse
Foam
1 bucket wash
Rinse
Ditto, every once in awhile a spritz of wet coat after rinse then rinse again :)
Lots of foam and water. Center township water authority sends me THANK-You cards at Xmas :)
I`m sure Accumulator will chime in here eventually..
I learned about the foamgun from (the now-MIA) YoSteve.
It took me quite a while (countless washes over a long period of time...and I don`t mean "a few months") to get my routine squared away, but now I can`t imagine ever washing without it. I`ve probably tried *every* foamgun-centric approach imaginable (and I have quite the imagination ;) ).
I need to write this up properly some time, but here`s the thumbnail-sketch version:
(Regulars here might notice some changes if they suffer through reading the whole thing.)
I mix up gallons of shampoo concentrate at ~7oz. shampoo + enough water to make a gallon. I fill the foamgun with that (I keep extra foamgun canisters full of concentrate handy). (Note that this same concentrate works well for cleaning LSPed wheels and the wheelwells/undercarriage.) I use a *LOT* of this shampoo mix so I keep a few gallons in old shampoo jugs.
I use the three strongest foamgun settings, varying between them as conditions warrant.
This rate of shampoo consumption and water use will disqualify my approach for many people but isn`t a problem for me.
I find presoaking with the foamgun to be of limited value. I basically only do it so there`s shampoo mix on the panel before I touch it with anything, although the extended dwell-time probably contributes something.
IME, mechanical agitation is necessary to get things clean. I use a BHB to get the "big stuff" off, but when used properly that`s too gentle to get "road film" off so I usually follow up with a mitt.
I do at least two phases, both with constant spraying of foamgun output at the point of wash medium-to-paint contact. First I use a Boar`s Hair Brush ("BHB") then I follow up with a mitt. On *very* rare occasions I`ll do a Garry Dean Wash Method rinseless wash after the BHB step, but I usually don`t do that until I`ve also do the mitt step (if I do it at all). I often do all three.
The basic idea is "dislodge and flush"- the constant stream of foamgun output flushes the dirt away as soon as the wash medium dislodges it. That way very little dirt gets stuck in the BHB/mitt (which would drag it across the paint under pressure, causing marring). If a BHB or mitt is touching the paint, the foamgun is spraying its output at the point of contact.
One hand holds the foamgun, the other hand holds wash medium. They are moved in tandem so the foamgun is always spraying output at the point of wash medium-to-paint contact (and I try to move the foamgun so that it soaks the entire BHB, which is longer than a mitt). There`s an element of "rub stomach/pat head" involved, but it became second-nature after a few dozen washes.
Wash media are always moved in in straight, short, interrupted "jiggling" motions, *NEVER* long, sweeping motions. The straight motions keep any marring that does occur linear (and thus less obvious than elliptical/circular scratches are), short motions keep any marring short rather than long, and the interrupted jiggling motions make it easier for the foamgun output to flush the medium clean while in-use rather than allowing it to get loaded up with dirt.
Steps:
-Rinse vehicle off, preferably with pressure washer
-Spray foamgun output on panel(s)
-Dunk BHB in wash solution bucket
-Spray foamgun output onto BHB to further prime it with shampoo mix
-Move BHB across panel, while spraying foamgun output at point of BHB-to-paint contact
-Rinse panel (either with hose or with foamgun on "clear water" setting, which is also good for rinsing jambs/etc.)
-Inspect, repeat if panel still appears unclean
-Dunk washmitt in shampoo bucket and/or fill it with foamgun output
-Hold mitt shut at cuff and spray foamgun output on its outside to further prime it with shampoo mix
-Gently whisk across panel while spraying foamgun output at point of mitt-to-paint contact
-Stop and refill mitt if shampoo seeps out before I finish area being cleaned
-Rinse panel
-Inspect, repeat as needed
This is all *MUCH* easier when the foamgun`s pistol-grip is replaced with a 90° shutoff, which I operate with my thumb.
The foamgun will often/usually rinse the BHB clean while washing (perhaps because of my boosted water pressure, might not work for everybody), so I probably don`t need to dunk it in the rinse bucket (and the reprime it with shampoo mix) as much as I do. The mitts don`t rinse out as well as the BHB so I always rinse them in the bucket and reprime them, but this might also be unnecessary as the rinse bucket hardly *ever* has any dirt in it at the end of the wash. The shampoo bucket stays clean enough that I usually just replenish it rather than dump it out.
Not the right approach for everybody, but it`s virtually eliminated wash-induced marring for me; I basically don`t need to polish any more even on daily-drivers that get used hard year-round.
Lol man that was the read brother! I am ever so curious to see at least one picture of one of your used cars.
So you basically do the same thing as me except you hit the panel with two types of tools instead of one like I do. I go with the mf chinelle sponge and it works just well.
What do you guys use for soap on the foam guns? I have a pinnacle soap gun and I simply throw some of my car wash soap in the bottle and let the water run thru it ?
