I decided to give the interior of my car a scrub on Sunday. It wasn't that dirty but enough to bother me.
Since I've heard so many good things about woolite and water (w/w), I decided to try it . I first wanted to test it out on one of my mats just in case. I actually used the no name brand woolite imitation. That's all I had in the house. But it shouldn't matter. Fine fabric washes should all be pretty much the same. Anyway, I started by vaccuming the mat to remove any/all dust and dirt. From there I sprayed the mat with woolite/water. I basically got the entire matt wet on the surface with w/w. From there I started scrubbing with my stiff brush to clean out the stains from my shoes. It was working pretty well. The stains were coming out. The w/w was foaming a bit. Next, I took my bissell little green machine and sprayed hot water onto the mat. I took my brush again and gave it a second scrub. This is where things got scary. The woolite really started to foam and get all sudsy. I took my little green after finishing the second scrub and extracted as much of the w/w until no more was being sucked into the tank. Even after extracting what I thought was all the w/w, the matt still had tonnes of foam in it. Just taking my finger and swiping it across the surface produced new suds. Up to that point I was not impressed with w/w. I ended up taking my matt and blasting it with water from my garden hose. I stood there for a good 2 minutes getting all the soap out. Unbelievable. Based on that, I did not feel comfortable spraying w/w onto my interior carpets and seats. After all, I can't blast them with the garden hose.
So after the w/w fiasco, I went back and got my bottle of 303. Ahhhh, this stuff is great. Cleans stains, and it does not foam like a mofo. I used it the exact same way as I used the woolite. I even blasted the 303'd mat with water to see if any suds got washed out. Nope, all clean water.
Some of you may be wondering why I spray my mats with hot water after scrubbing in the soltion. I do this because I find that I can extract the solution (and a whole lot of dirty water) from the sets and carpeting. When I try sucking out just solution nothing really comes out. I'd rather not leave the cleaning solution embedded in the fibres, as it will cause the upholstery to get dirtier, faster.
I'm sure glad I tested w/w out on my mat first. There is no way I would have been able to blast my interior carpet or seats with water from the garden hose.
Based on this experience I would not recommend w/w. Buy a dedicated automotive upholestery cleaner.
