I'm still waiting for the car wash thingie but I did receive a free sample of the Mr. Clean Magic Eraser (www.homemadesimple.com/mrclean/eraser_useage.shtml) It's a white dense foam pad that you soak in water, wring out, and "erase" dirt and grime from walls, tiles, etc.
I tried the CD test and it scratched a bit and they do say it's not for use on polished or satin surfaces. They also warn you to try it in inconspicuous places to check for scratching.
I wet it down with Z7 and used it VERY GENTLY on:
- 1/2 my windshield: It cleaned away spots and bug juice effortlessly. The 1/2 I used it on is noticeably clearer and dried without any water spots.
- a chrome rim that had some paint overspray: Took the overspray off after multiple passes when a clay bar could not. It did not scratch the chrome at all.
- Polished aluminum exhaust tips: They are so shiny now I need sunglasses!
- Plastic headlight covers: here I was a bit nervous but it did an excellent job.
- A 1951 license plate that I'm sure hasn't been cleaned since 1952: it cleaned it right up, took off every bit of grime and antique dirt.
Basically it's like a clay bar but more aggressive. I can see using this on all parts of your car that are not sensitive to scratching such as painted surfaces. I'd say it if you use clay on areas other than paintwork such as glass this product will do a better job.
All in all this will make a good addition to your detailing kit. I think they are in the supermarkets now and I'm definitely buying some this weekend.
