mgm2003
Here’s a brief review of my Metabo Polisher after 3-4 hours of seat time.
Metabo 12-175 Rotary Polisher
Variable Speed: 700-2200 rpms
Spindle Lock for easy pad removal
10 amps
Weight: 5.8 lbs
Length: 14"
Warranty: 1 year
Pro’s
Con’s
10 amps
Weight: 5.8 lbs
Length: 14"
Warranty: 1 year
Pro’s
- Lightweight (compared to my 8.5 lb Dewalt)
- Very good feel/ergonomics. The curved rubber nose of the polisher provides a very solid/stable feel.
- Quiet Running Operation vs. my Dewalt
- Very balanced
- Slow RPM start up vs. immediate start up @ your selected speed.
- Very easy to swap out backing plates
- I do not get fatigued as quick as I do with my Dewalt
- Very easy to learn rotary. The low 700 RPM speed allows you to get a good feel for a circular polisher vs. a DA polisher. The low speed also helps you identify the proper balance/position for operating this tool, and you are much less prone to making a mistake (i.e. burning the paint). At 700 RPM you would have to run the pad edge on the paint or hold down the polisher in one spot for 10 seconds or so to do any damage.
Con’s
- The speed dial is located at the rear of the machine, near the cord. It’s almost impossible to adjust the dial, and see the setting ‘on the fly’. I’m sure I’ll get a feel for the speed setting, by the sound it’s making, but I’d much rather have the thumb wheel on top like my dewalt where it’s easy to read and easy to adjust.
- No speed trigger to ‘feather’ in your polish, or control speed as you polish up to the edges.
- Price. This isn’t a budget machine, and I hope the durability/reliability are in line with the price.
- At 5.8 lbs, you are tempted to put some weight on the machine. IMO, this is a big ‘no-no’ for rotary polishing. I let the weight of the machine, aggressiveness of the pad, and chemical do the work. I’m just there to guide it.
