imported_Ivan Rajic
i wanted some input on what to order next...
for a while, i've been using meguiar's #4, #2, #9 and #3, followed by klasse
after browsing the forums here for a few days, i've been hearing good things about the other meguiar's products though, particularly #83, #80 and only one that i've been using which is #3
i wanted to order some supplies from meguiar's and i wanted to get the products based on their table of cutting power (one that is on their bottles) so i figured i would go with #84 (in case i need it because i've needed it in the past), #1, #2, #9, and #3... basically the odd numbers on the "cutting-chart"
after reading the forums though, like i said, i'm thinking of geting #83 and #80 either in addition to my list (84,1,2,9,3) or as a substitute for some of those on the list
i really like #9 because it takes out a lot of the smaller/lighter swirls so that i don't have to use anything more abrasive on the paint, and i'm afraid if i substitute #80 for #9, i will introduce a bit more hazing into the paint and then need to use #9 after anyway
i also like the #2 but wouldn't mind replacing it with #83 because 1. i heard very good things about it, and 2. i usually go over it with a less abrasive polish (#9), so if any hazing appears from #83, it should be gone after #9
so, right now i'm thinking of getting #84, #83, #80, #9 and #3...
what do you guys think and what polishes do you guys suggest i order??
EDIT: i recently heard that #9 has some fillers so i think i'll replace #9 completely with #82, unless you guys think it's fine to use #9, then #3, then klasse???
also, i noticed that #9 and #82 have the same cutting power according to meg's chart, so i was wondering what differences are there between the two??
lastly, i'm planning on getting the #7 show car glaze because i've also heard great things about it and looked at photos where cars look amazing after a #7 application...
my question about it is... do i seal it with klasse or is it a sealant itself ?? am i fine using aio and sg after #7 has been wiped off??
thanks a lot in advance and sorry for such a long post, i just had these questions on my mind and had to ask
thanks again,
ivan
thanks again,
ivan
