Langka, which one should I get?
zimmerDN
The blob eliminator or the paint chip repair kit?
The repair kit comes with a cleaner for prepping the paint which I believe can be done with alcohol/water mix. But the kit also comes with a sealant for the touch up paint. Is that necessary? :think:
Anyone with any experience? ;)
Actually I tried it with laquer thinner and polishing compound, worked just as good without the bling$$$ bling$$$
Nobody uses the sealant, just mix your paint with a clearcoat for larger chips.
Yup just get the blob stuffy and I suggest a sanding pencil. I still have yet to get a near perfect match, but it looks better than primer or metal.
zimmerDN said:
You can get the touch up paint from dealership but where do you get the CC from?
I got my clearcoat from paintscratch.com along with the touchup paint. There are varying opinions about the need to use clearcoat for touchups. I also purchased the Langka kit with blob eliminator. I have two chips I have to do, but haven't done it yet. I think I'm trying to get my courage up. I think that there are certain paints that PaintScratch will not sell without a purchase of clearcoat as well....I seem to remember this from looking for touchup stuff for my daughter's Bug. I also got some lacquer thinner for cleanup. I might use the Langka sealent on the repairs and leave it on for at least 30 days to protect the repair until the touchup paint is fully cured and then do a full detail of the hood again with my PP/VM/RMG/UPP/Natty's combo that I like on my Silver Mist CR-V.
