Lake Country vs. Meguiar's Polishing Pad Chart
Todd@RUPES
Just a regular guy
This chart is for general comparison use in terms of how the foam or wool material of the pad should perform against each other.
Keep in mind that there are many variables when selecting a foam pad.
Pad Diameter: The diameter of the pad controls the total contract surface of the area as well as what speed the pad moves across the paint in a given movement. On a rotary polisher a larger pad will act more aggressive because the outer edge of the pad is moving at a faster rate. On an orbital polisher a larger diameter pad will act less aggressive because of the increased deflection in the pad as well as the increase in friction and mass.
Pad Face Design: In general, flat pads, such as our Hi-Gloss Classic Flat style or Meguiar's SoftBuff 2.0 have the largest contact area against the paint. This makes flat pads more aggressive in polishing action when applied with rotary polisher but may cause random orbital polishers to bog, reducing cut. The increase in surface friction will also increase the amount of defection in the pad.
Pad's that have dimples, pockets, a convoluted 'waffle' patter, or are cross cut will be less aggressive on a rotary polisher and more aggressive on a dual-action polisher for the same reasons.
Helpful links.
Choosing a Machine Polisher
CMA Polish Range Comparison Chart
Meguiars M105/M205 Polish and Pad Comparison Chart
Lake Country/Menzerna Polish and Pad Comparison Chart
Understanding Lake Country Polishing Pads and Foams
Removing Paint Defects
Choosing a DA Backing Plate
Todd,
This is one of your best (not for the graphics necessarily) but for the function. All of my pads are either LC 4" or Megs 6.5" (with a few LC 5.5" mixed in). I had NO idea the 8006 pad fell in between the orange and white LC pads and that is EXTREMELY useful info.
Well done.
Great chart Todd, sure will come in handy since i own most of the pads you have listed.Thanks for taking the time to put together all your charts.
Wow, so the german green is actually less aggressive than the white? I thought it was somewhere in between the orange and white with the finish of a white pad? Learn something new everyday!
BTW, love the "pocket" chart! haha! I need to start printing this stuff off and make a reference book!
I had to make these up and post them here at work when folks come in and buy / p/u their products they can see these awesome charts!
Great chart Todd, yet again!
One thing I'd like to point out is that Meguiar's W5000 Double Sided Wool pad is actually our most aggressive pad overall, topping even the red WWHC7 So1o wool cutting pad.
Thanks for stoping by Michael and thank you for pointing that out. These charts, with the introduction of LC's newest pads, are already outdated and due for an overhaul. Will the madness ever end?!:scared:
BTW, love the "pocket" chart! haha! I need to start printing this stuff off and make a reference book![/QUOTE]
been doing that for a while now... thanks again todd
