Jaguar intense paint correction- Atlanta Detailing Detailed Designs Auto Spa
Jean-Claude
Keeper of the beautiful
The owner contacted me and said he saw some pics of a NSX I did some correction on and wanted me to clean up his Jaguar. He indicated that it had scratches, but once seeing some pictures of the hood via a camera phone I saw something more. The hood and roof were plastered with water spots and an insane amount of acid rain etching.
I tried to give him a consultation once I met up with him but he said he didn't care, he wanted me to take care of it. I shrugged and got to it. I did a test spot on the hood for my own sake and to be able to give him an accurate price after he left for work and got to it.
This job took a total of 48 hours to complete.
Before starting I took a few shots. It was very low sunlight so I had to make due with a flood light to capture some of what was there.
Before washing the body work, I cleaned all the rubber and plastic bits with 1z Einszett Plastic Deep Cleaner.
Pre-rinsed and foamed with house blend pre-treat.
Rinsed house blend pre-treat off.
Washed with house blend shampoo.
Doing my thing on those little areas.
After claying small portions of the car. Went through a full bar of clay over the whole car.
Some of the worse areas:
The roof saw a number of passes to get these results. The owner was made aware that some of the acid rain spots and a few of the scratches on the car were too deep to remove without wet sanding. He was down for some minor spot treatment on the roof and the full hood.
Roof:
Before
After
Hood:
By far, the worse off part of the car.
After working it over with a number of products, machines, pads and methods, I realized that wet sanding it was going to be the most cost effective and quickest way to get the results.
This was after a pass and alcohol wipedown. This just goes to show how one can be fooled if you don't clean it up with alcohol. It took a number of passes and wipedowns to get it cleaned up properly.
To give an idea about how bad the acid etching was here is a picture of the edge of the hood. The edge was not sanded but time was spent to clean it up. These marks were probably the shallowest ones on the hood. The left side was the fender prior to being worked on.
*all buffer trails were fixed during the polishing process* :)
Befores:
Afters:
Befores:
Afters:
Befores:
Afters:
The finale:
Atlantadetailer.com
Detaileddesignsautospa.com
That's amazing work, Jean-Claude. I can't believe how rough that thing looked in the befores. The transformation is night and day!
Nice to see the cat getting some much needed TLC...great detailing / paint restoration as always
Jean-Claude- Great work! And I loved those pix where you're using the BHB to get into tight spots :xyxthumbs
Man that thing sure looks nice now!
What's the clear like on those, just in case my pal actually *does* take me up on my offer to do his?
Oh, and I'm now guessing that I was completely wrong about that car's history! I'd thought it was probably a new acquisition by maybe its third owner, but it kinda looks like he's had it for a while and merely let it go.
At first I was wondering what in the world BHB was. I had to go back and look at the pictures to figure out what you meant! haha
It's hard to pin the paint down. Some areas were like butter and some areas became a grind. Overall, taking the extremes out, it was average paint to work on. Not the hardest I've seen and not the easiest.
Once measured, I was sure it was all original paint. One nice thing is that on average the paint measured about 180 μm.
Holy Ballz! First off, amazing job. Second, when I see threads like this I can't help but wonder about these vehicle owners. They obviously make a good living which requires education, hard work and a great amount of care in whatever they do. Their car's however show a complete lack of education, care and hard work almost to the point of negligence. Even if I made my living fixing what these a$$holes do to their cars I would still hold them in contempt for being so clueless. How can you have something that nice and not give a damn about it?
First and foremost regarding the transformation: in a word, SPECTACULAR!!!!
I share your sentiments exactly although they were worded a little strongly. Yep, even if I had more money than God you better believe I would still take care of everything I own with pride and care if I personally did so or found the very best individuals to do it for me. Some people treat their possesions like all of them are disposable. It's not about their station in life, it's mostly just how they generally are for whatever multitude of reasons. We don't understand them any more than they understand us so given that, I'm super happy I have a place like Autopia to interact with others who are more like me.
The current owner said it was pretty jacked up when he got it and since it was so bad off he didn't have a problem using a wash n swirl weekly. He now knows not to.
Ah, OK...won't really argue with that. Bet he likes the car even better now.
First, that is a great job. I can't imagine how bad the looked in person.
Second, what a gorgeous color on that Jag. Just dark enough to show depth and gloss, and light enough color to show the contours of the vehicle.
All in all just wonderful work and a great post.
