IPA after every step?
JpiRally
Do you IPA wipe down after every polishing step? say you were going to polish, then switch to a different cut, would you IPA between them? Or do you get all your polishing done and then do your wipe down right before you do the LSP?
Thanks...
joe
I wipedown before each step to ensure the desired results were met. However, it won't make the next step more or less effective.
yeah...I tend to wipe down to ensure of the results to start with a clean slate.:) just wanted to see what the consensus was.
joe
a.k.a. Patrick said:
I never IPA wipe, period..............
I was the exact same way until I encountered a) filling issues with Menzerna 106FF, and b) residual oils with M205. Those are the exceptions to the rule for me.
Generally, I only use IPA/PrepWash wipes after M205.
No, I've never had marring unexpetedly "come back" because I didn't wipe, except for that 106FF situation. My wiping after M205 is more a case of not liking how the oils look under my SunGun (and sometimes under other conditions too) than anything else.
