mjlinane
My name is Mike
Initial Impressions: Gtechniq G1 Clear Vision Smart Glass
Introduction:
A new product line added to the ACC fold gave me all of the excuse I needed (which, admittedly, isn't much) to buy and try.
Thanks again to Corey for providing the format.
Product
Product Claims:
From Autopia Car Care site - Gtechniq G1 Clear Vision Smart Glass
"Keep your windows coated in extreme protection!
Creates a hydrophobic surface which repels rain
Forms a chemical bond for long-lasting results
Lasts up to 30,000 miles of driving
Gtechniq G1 ClearVision Smart Glass is not your typical rain repellent! Gtechniq formulated this amazing coating to form a chemical bond with your vehicle's glass giving you extremely long-lasting results. Gtechniq G1 ClearVision Smart Glass has been tested to be effective up to 30,000 miles of driving! See the road no matter the weather with G1 ClearVision Smart Glass.
Gtechniq ClearVision Smart Glass is like a paint coating for your windows. This highly hydrophobic formula promotes extreme levels of water beading, causing rain and water to run off your windshield. This keeps your windshield clean and your vision clear at anything more than neighborhood speeds. Gtechniq G1 ClearVision Smart Glass has the same self cleaning effect as Gtechniq's range of surface coatings reducing the need to clean your windshield.
Gtechniq G1 ClearVision Smart Glass not only makes wet weather driving safer, but the tough coating makes it more difficult for items to stick. Bugs, bird bombs, sap, water spots, and even ice are easier to remove. Smart Glass can even withstand repeated windshield wiper usage. This easy-to-apply formula does not smear and provides perfect clarity, no matter what mother nature throws your way.
On new glass simply clean and apply the coating using the applicator pads. Gtechniq recommends 3 coats on the front windshield and 1 coat on side and rear windows. On older or weathered glass, Gtechniq recommends using Gtechniq G4 Glass Nano Polish prior application for complete bonding and crystal clarity."
Details:
1.- Packaging: Plastic bottles (G1 & G2)
2.- Directions: Clearly labeled
3.- Viscosity: Like alcohol
4.- Color: Translucent
5.- Scent: Light alcohol
6.- Price at time of review: 15ml = $ 15.99
7.- Manufacturer: Gtechniq
9.- Made in: British company anyway.
Other Products Used:
Supplied applicator
Cotton terry
Preparation:
Believe preparation is extremely important when using one of these long lasting products. Cleaned glass with Megs D120 Glass Cleaner, "clayed" with Diamondite Spray Clay, hand polished with Duragloss #755 Nu Glass + yellow pad, washed (with car) CG Honeydew Snow Foam and CG Glossworkz, rinsed and followed with Carpro Eraser. (And that was on excellent condition glass - being the belt & suspenders guy I am.) If I hadn't had the above, would have bought and used Gtechniq G4.
Application:
Shake well. Apply a couple of dabs of G1 on supplied applicator and spread spread on glass - 3 coats on windshield. 15 min later, similarly apply G2 and immediately buff with cotton terry.
Observations:
Light alcohol smell. Easy to apply and remove. Flashes rather quickly so can be hard to see where you have applied. A little goes a long way (used about half of each on the Sonata). Very clear and slick finish.
Does it meet its claims? In general.
Pros:
1.- Easy application and removal
2.- Very clear & slick finish.
1.- Durability - We'll see.
Cons:
1.- None.
Final Observations and Summary:
Like Gtechniq T1, durability will be the deciding factor on just how much I like Gtechniq G1.
I will update with beading pictures next week and periodically after.
Comments and questions are encouraged. Thanks for viewing!
Introduction:
Product
Product Claims:
Details:
Supplied applicator
Cotton terry
Preparation:
Application:
Observations:
Pros:
Cons:
1.- None.
