Yup, I have the IK1.5, IK9 and IK Multi. They work well. The IK9 is my favorite and the one I use the most.
With the IK1.5 I find if I do not have the right ratio of product/ water it won`t foam well or spray well. I started using less of the product and more water and it seems to be performing better.
Nice. They have three different foamimg adapters. One for dry, regular and wet. I do get a lot of clinging from the dry and regular. The wet adapter is true to the name and provides wet runny foam.Bought the combo pack and just trying to use Hydro Foam on my wheels and aluminum grille. Hope it foams enough and clings for a bit.
Anyone try out the new iK sprayers?
I have the 1.5 for Ammo frothe and one for wheel cleaner/iron remover. I use Meguiar ultimate wheel cleaner at 3 to 1 and it’s awesome!
I got 3 of the 1.5 foamers, for wheels. Got to pump alot but worth it. Thick rolling foam, with the purple tip !
Looking for a different wheel cleaner that doesn`t stink like my Griot`s heavy duty does. You say MUWC 3-1 is awesome ?? :idea
You will pump less with the iK9. iK9 for complete foaming and iK1.5 for wheels and fender wells.Is the bigger one better than the smaller handheld one?
Does one produce more foam over the other?
