Ideas for scuffs
phareous
Anyone have any ideas I can try for door scuffs? Cleaning with apc did nothing so I`m guessing these are light scratches. It`s a brand new car and I`m a bit perplexed how they even happened
Sent from my SM-G935V using Tapatalk
Try a Mr Clean magic eraser thing, lightly!
Usually we touch the doors with out shoes on the way out for some reason. If it`s a mark from a sneaker it`ll usually come off, if it`s a scratch from a leather sole shoe, not so much
M
Try some type of plastic trim coating such as 303 Aerospace. Anything that may darken the scratches. I’ve used Nextzett Deep Plastic Cleaner and removed things I thought were scratches, so you might try that.
I’ve had good luck removing plastic/rubber scuffs from interior plastic/trim with Stoner’s Xenit Citrus cleaner. Hard to tell if these are scratches or scuffs that can be removed. Goo Gone may be worth a shot.
Thanks guys.. The magic eraser did great and I also used a little novus plastic polish/cleaner.
I found this interesting! I wouldn`t have thought that further abrasion would make it better-not-worse, but I`m sure glad I was wrong.
To me the marks looked like transfer from the sneaker to the door panel rather than scratches into the panel.
That`s why I suggested the eraser, and if you`ve tried one on that harder textured panel it`s pretty much impossible to scratch it with those sponges. The softer panels and dash/upper doors it`ll sometimes marr a little
M
I can`t rub some interior surfaces on our vehicles with even a soft cloth without messing them up abrasion-wise. Eh, the newest car we have is 10 years old!
Phareous- That second pic looks like there`s a discernible spot where you fixed it, like what I`d worry about...or is it just the pic?
Mooser- Seems like any plastic surface I`ve ever touched with a Magic Eraser got marred. Even for household use, I basically only use them on ceramics/etc. as the simply mar *anything and everthing* that isn`t rock-hard, at least to some extent.
