Pretty, ain't it?
I was polishing out a Lotus Elise today using my UDM, DAS Scratchbuster white pad and Optimum Compound (they have pretty hard paint!). I had opened the driver's door and was polishing the top of the door sill (you have to open the door to get to all of it). I was sitting down, putting moderate pressure on the UDM (so it was still spinning quickly), the speed was 6. All of a sudden, there was white foam everywhere and I immediately pull the machine off the car but the damage was done. A 1" spot on the leading edge of the door sill, right down to the primer. :wall
I showed the customer the spot and the pad and explained what happened. I was kind of suprised he showed so little reaction and simply said "well, that is obviously an accident". I told him I knew of a high quality body shop that specializes in high end cars and I personally know and trust the owner to do the work right and that I would pay for it.
Anyway, I switch to a Meguiars burgandy cutting pad to finish compounding the car, then the final polish (OP, yellow Meg's pad) and then sealed the paint. He asked me how much and I told him to get his car fixed first and that if it was all right with him, I'd just apply the cost of the exterior detail to the cost of repairing the door sill. I told him I wouldn't feel right taking his money at this point. I also offered to make up the differnce in detail work and that seemed to make him happy because other than the door sill, he seemed really happy with how the car turned out since I got out all the dealer installed swirls (except two small areas where it was obvious the paint was severely scuffed but even those areas were much less noticable) and 95% of the other defects in the paint.
He then mentioned he had thought of having that door sill repainted anyway due to some chips, so maybe he will call us even if the cost isn't too bad.
I felt really bad though, he called me because I was highly recommended on a Subaru board (he also has a WRX) and I end up damaging his car.
Anyway, here is the pad:
You can see the hole in the back, burned right through in an instant.
