AutopiaTech
Moderator
After a lifetime of saving, pinching pennies, and living smart, you finally have the cash to purchase a slightly used Ferrari California. It's not the new 599 GTO that you've been dreaming about since you heard the exhaust note on Youtube, but it's still a Ferrari. So it's March and you're taking a road trip from California to Florida to spend the weekend at some detailing event and car show that's held in Stuart every year. While cruising through Nevada you finally decide to put the windows up and crank on the air conditioning. The cold air feels nice blasting through the vents, but what is that horrendous smell? Air conditioning off, windows down, time to enjoy the purr of the high-revving naturally aspirated V8.
Maybe the heat is getting to you, or you forgot to eat breakfast that morning, because all of a sudden you realize you're driving a ten year old Honda Accord with 183,000 miles on the odometer. You should probably quit day dreaming, and keep your eyes on the road. Air conditioning? Sure, it works a little bit, but don't even think about turning it on while merging onto the on ramp. This ain't no sports car! Luckily you're earning .6% interest in a savings account, so that slightly used Ferrari is just around the corner.
If your car has a foul odor in the air conditioning system, and you're not sure how to get rid of it, 1Z has just the product for you. Aptly named Klima-Cleaner, this air conditioning treatment will effectively eliminate foul odors at the source. Don't get this confused with an air freshener or odor fogger, because it's not. 1Z Klima-Cleaner is designed to cleanse air conditioning systems by deeply cleaning the evaporator core, the heart of the air conditioning system. At the evaporator core, condensation accumulates over time resulting in a foul odor. 1Z Klima-Cleaner is an effective means of eliminating odors so you can enjoy the blast of cool air from your air conditioner without gagging or feeling sick from the smell.
1Z Klima-Cleaner is so easy to use, anyone can do it. It comes in a 8.5oz (250ml for all you Europeans) aerosol can along with a spray hose that's long enough to snake its way through your air conditioning vents.
It's real simple: With the ignition, air conditioner, and fan speeds turned off, adjust the fan position to the direct setting. You do NOT want the fan position set to defrost or the foot setting. Shake can well, and snake the included spray hose into the center air conditioner vent. If you feel it binding or grabbing somewhere, adjust it so it inserts smoothly.
Once that is completed, fully depress the trigger to dispense contents. While you're pressing down on the trigger, thick foaming solution will work its way to the evaporator core, the heart of the air conditioning system.
After several minutes, the contents of the can will be empty. Waiting no longer than 30 minutes, open the windows of the vehicle, and turn on fan setting to maximum while air conditioner is set to the ON position. Do this for one minute for the system to completely clean out.
Now you can enjoy having the blast of cool air from your air conditioning system without having to deal with any foul odors. Keep driving your beater, put in your time, and before you know it you'll have that Ferrari California. :rockon
1Z Klima-Cleaner
