Hello all,
Thanks to all for the helpful posts I've used in getting my neglected Protege back looking good. I'm getting ready to put summer wheels (aluminum w/clearcoat) on and am cleaning the daylights out of the inside surfaces. Lots of chunks of tar from the previous owner who just absolutely criminally neglected this vehicle. Also a lot of brake dust that Eagle One A2Z really cut through- thanks for the tips! WD-40 is powering through the rest of the tar spots and some of the brake dust, and I now have another can of brake cleaner spray to try to get the rest of the embedded brake dust off. Learned my lesson on the first wheel with 0000 steel wool. Oops. :wall
What I'm discovering now, though, is that she apparently didn't rotate the tires. Mazda had a problem with rotor hubs rusting badly, and actually had a dealer TSB to paint them to halt the rusting. You can see all the corrosion and rust sticking to the inside center of the wheel. See below:
There is rust as well as some kind of corrosion on the metal. I'm figuring the moldy-looking spots are brake dust that has etched into the back of the spokes and the back edge of the wheel itself. The etching isn't as much of a concern as that corrosion. Any ideas?
