Angus
AspiringProductSpecialist
Over the weekend my brother-in-law approached me about how to clean up his recently acquired bass boat. For a secondhand boat it seems to be in fine mechanical shape but the rest of it has seen better days. Thing is, I've never detailed a boat before but I really want to help him out and make it look great. Plus its a chance to learn something new.
The subject:
[FONT=trebuchet ms, sans-serif]
Hull problem areas:
What are those spots from? They seem too oddly placed for normal oxidation. Could they be from an acid washing that wasn't properly rinsed off?
Would Marine 31 Finish Cut Metal Restoring Polish take care of the aluminum hull?
Since I don't have access to a rotary would my GG 6 in combination with wool 6.5in pads produce enough cut to effectively polish an aluminum hull? Could it remove those odd white chalky areas?
Once corrected, what's good to protect and maintained a hull?
Additional problem areas:
Best way the clean off mold/mildew? Remove spots from vinyl? OPC 3:1? A dedicated marine vinyl cleaner?
I'm very mindful of his limited budget and don't want to blow it on products that aren't going to deliver the best possible results. At the same time I want to be realistic on what we should expect to achieve. The boat will primarily be used on lakes and rivers if that helps?
Thanks in advance for any help!!!
[/FONT]
The subject:
Hull problem areas:
[/FONT]
