Glass polishing with rotary?????
SVR
Dream Machines
Want to know all about removing swirls and scratches on old type glass and modern glass.
Proper speed, pressure (none, light or medium), products you use and technique
I have
Autosmart glass polish
1Z glass polish
Detailers pride glass restorer
Diamondite glass surface cleaner & speed clay
SSR 1, 2, 2.5 and 3
Menzerna Powergloss, IP, FP I, FPII (RD3.01 and RD coming)
Poorboys pro polish
Sonus SFX
Clearkote VM, RMG, Blue moose, compound moose, Yellow moose
P21s polishing soap (says it can do glass on container) and finish restorer
Lots of other paint compounds, polishes and cleaners
Pads
3M black and white waffle
Edge classic foam yellow, green, blue and white
I followed a hint from here and PC'd my glass last weekend. I used Carlack 68 at a speed of 4-5 and a white LC pad and got great results - it didn't do much on the few scratches I have but it shifted all the water spots.
Finished with NXT glass cleaner and very happy with the results!
Try the glass polishing system from Eastwood if you want to get scratches out of glass. It comes with the compound which you mix up and a wheel which attaches to a drill. It works really well.
The pad that comes with this kit is very dense. I'm not sure anyong makes a pad like this suitable for a PC that would be able to remove any serious scratch.
