Glass master pro
That's a great tool. Really great for certain cars/windows...I just don't find myself using mine much anymore (I'm not even sure I know where it is)...maybe because of the dedicated bonnets and not having that many.
jesselyons2002 said:
I use it and return it. I found it not really doing it's job.
That sucks..I just bought it because the windows on my car are a bear to reach at the very bottom corners
You'll be fine, just wash the bonnets often (like with any glass towel) or you'll get streaking. With the bonnet you can't fold it to a clean portion so it gets gunked up pretty quick if you are doing dirty windows.
I got it and used it couple times so far. It is good if you can't reach certain portions of your windows, like I do. I have a 330xi and it is impossible to clean the rear windows from inside if you do not have something like this. I have to admit it is not perfect and sometimes hard to use, but it is a must for me. As mentioned before, need to keep it clean and use just enough cleaner on it, otherwise it will streak.
I've had one of these for years. On cars with long steeply raked windshields it's a lifesaver. The bonnets it comes with though are not very good. I stopped using them. Instead I drape a waffle weave glass towel over where the bonnet would go. It stays on fine and works much better.
