I am the new (to me) owner of a 2011 BMW 328i. The car is great, but it has been plagued by a chemical smell that comes out of the vents when the heat or AC is run. It is kind of subtle at first, but if I run the vents with the windows closed on a longer drive it eventually makes me dizzy, my throat starts to hurt, and sometimes I will get a headache. If I don't run the vents (system totally off) and just roll down the windows, the smell dissipates fairly quickly and I don't feel sick. I live in a state with cold winters and hot summers, so not using the heat/ac system isn't really an option.
The car has been inspected several times and the mechanics can't find a fluid leak that is responsible for the smell. It doesn't smell like mold in the AC, which is a problem I have had on past cars. It has been suggested that someone might have tried to de-odorize the vents with a chemical prior to my owning the car, and somehow the smell is stuck in there.
Has anyone run across anything like this before? Is there a way to pinpoint where the chemical smell is likely coming from or what it is? How would you go about cleaning out the vents in a way that doesn't add more chemicals to the system?
thanks for any suggestions
