512detail
Poorboy`s Beta Foam Sample Review
Thank you for giving me the chance to try this new beta foam soap sample.
I had to dig up my ag foamster gun. Haven`t used it in close to 2 years.
I get a lot of foot traffic when I`m working outside. One of my neighbors literally stopped by the other dau when i was working on the orange super bee and he dropped today for a 1step + wax detail and interior steam cleaning. So I thought this would be a fantastic opportunity to test the soap.
I need to frame this review properly first... I have used this foam gun less than 10 times in my lifetime. I have tried only DP xtreme foam and I honestly don`t remember much about using it. I wasn`t a true Autopian at that time.
How much to use?
All of it! (4oz)
Filled almost to top with tap water.
The test subject.
Rinsed then foamed. Had to adjust the slider to get most foam.
Wala!
I don`t know if that`s a lot but it sure worked well IMO. Grape scented foam, very nice.
Thoughts-
Smells FANtastic, I hope the scent doesn`t change but I`m sure I will like any scent they change to.
Foam amount seemed quite sufficient, good enough I decided to skip the 2bm.
I only added 1 bucket with a grit guard. I kind of washed with an omage to the Accumulator wash method, except not nearly as thorough I`m sure.
The foam provided good lubrication for my lc wash wedge, foam block and regular chenelle mitts.
Cleaned up pretty nicely. Rinsed off in typical Poorboy`s easy fashion.
Good stuff.
Should it be thicker? I don`t know. If making it thicker means ot has more foam, then sure I`m game for more foam.
I used 4 oz because The Guz said he thought 3 would be better from his review. I didn`t really know what I`d do with an extra 1 oz so I poured it all in and filled to tol with water. Still have a little less than half left and i felt i used A lot of foam too.
This made me remember foam guns are cool and fun. Yes I`m sure a lance is better but I make it by with what I got just fine.
Thanks for viewing.
-Brandt K.
Sent from my SM-G900P using Tapatalk
How much to use?
All of it! (4oz)
The test subject.
Wala!
Thoughts-
Good stuff.
Thanks for viewing.
-Brandt K.
