Finish First ??
MrSelfDestruct
We have a can of this at work (that we never use.. lol) and I was wondering how good it is?? What it's comparable to?
http://www.finishfirstpolish.com/orderpage.html
Finish First Polish
FINISH FIRST uses a synthetic emulsifier cleaning agent to dissolve tar, road film, dirt and organic contaminants which cling to the paint even after washing. With this dissolving cleaning action, you will not create those "swirl marks" in your paint finish usually caused by organic wax cleaners. Not only will FINISH FIRST not create swirl marks, the cleaning emulsifiers will dissolve the contaminants embedded in old swirl marks and make them disappear. FINISH FIRST is unique to organic waxes because of its synthetic formula.
FINISH FIRST actually works better if you let it dry on your vehicle before removal for a minimum of 15 minutes to 2 hours. FINISH FIRST POLISH/FINISH is durable, weather resistant and able to build layers in order to enrich the depth of gloss. A regular wax coating, which is not durable, lacks the ability to build layers because the solvent grit of the second coat destroys the first coat. With FINISH FIRST the more coats you apply, the deeper the gloss and the greater the protection.
I used it years ago and really liked it before I discovered all the other products we discuss here. It is a polymer that is relatively easy to use and it is quite durable. Again a little goes a long way and the results can be very pleasing.
I used it on a Black Gran Prix and loved the results. You can put it on and take it off a day later without any problems. I used to leave it on overnight to "cure".
