Tex Star Detail
Formerly TexasTB
I have all the 6 inch pads for the PC. I got a couple of them used. Is the BLUE pad suposed to be VERY soft? As in, when using it, it goes flat? Seems like a sponge to me....
holland_patrick said:yes very very soft..
TexasTB said:I purchased a white pad not more than a month and a half ago, and is stiff like the cutting pads. When did you switch these 2 to the polishing foam for the blue and white?
Also, I picked up an orange pad from another member here, but do not see it on your website. Any reason for that? Such as discontinued? Wasn't too sure.
holland_patrick said:^^^^^ the blue/white foam is above..
the orange is not on the site but it's a eruo foam thing.. a med cut pad..
The Edge said:Sorry for the delayed repy Texas. Someone called with the exact same question and I thought it must be you so I did not reply to your question. We switched to the soft white and blue about 8 months ago but some distributors still have older inventory. If you want the softer ones just send them back to me at the address below and I will replace them with the softer versions. As for the Orange it was made in response to a European demand and we don't fully advertise that we make it but it is available from both Autogeek and Detail City. Its kind of a medium to light cutting pad that has some polishing properties as well.
Aaron Krause (President & CEO)
777 Henderson Blvd.
Suites # 1 & 2
Folcroft, PA 19032
Phone: (610) 583-4883
Fax: (610) 583-4885
Email: aaron@dedicationtodetail.com
Website: www.edgepads.com
PEI Detail said:Look at this.
A manufacturer who is willing to replace a pad held by an older distributer who got paid for his/her pad and distributed in good faith.
This is not a Walmart world on here.
The Edge said:When we first introduced the DA pads we used our DuraFoam for all the colored textures. We found that the blue and white which are polishing pads for glazing and waxing were too stiff and did not produce enough shine. We then began using our regular polishing foams for the blue and white but keep the yellow and green which are cutting and buffing pads in the durafoam. I hope this helps. The older stiff blue and white still work fine but don't produce as high a gloss especially on dark colors as the softer pads we make them in now do.
joyriide1113 said:Which was my frustration when I first began using the rotory. I bought it along with the edge pads and found myself with holograms even when using their finishing pads. Upon switching to a different pad the halos went away.
The Edge said:As I mentioned those pads were made for the PC on a DA machine not the rotary. I don't think that our rotary 8 inch pads would leave holos if being used properly.
