Edge 2000 review by mgm2003
mgm2003
Here's my review of the new edge 2000 pads and quick adapter. I purchased an adapter for my dewalt rotary and PC.
1. Packaging & Labeling. Is it well packaged? Are the labels durable?
-Nice durable package. Good description of how to attach/detach the pad. I use the package to store the pad in after each use.
2. Helpful instructions on label?
-Very good instructions on the plastic packaging (although it's pretty self expanitory). I especially liked the tip about reattaching the pad after you wash it out, and set the polisher to a high speed to remove excess water. It's a very useful tip for drying the pads.
3. Value. Is the product a good buy?
-I think the edge pads are very good buys. So far I've detailed 4 cars and 1 SUV with them, and they still look brand new! I also like the fact that they are double sided, which is a real time saver.
4. Easy to use? Hard to use? Did you read the directions and use as directed?
-These pads are a piece of cake to use. I really like the fact that you can quickly interchange them between the rotary and PC. The built in backing plate sits between the pads ensures you lock the pads on center every time. I did have to buy the 6oz counter weight for the PC, because at settings of 5 or above there was a noticable vibration. Not a huge deal, but definately noticable. I also burned the skin off of my knuckles when using the PC. These are thick double sided pads, that don't leave much room between your grip and the pad.
5. Will I purchase again.
- You bet ya! The edge2000 pads are durable, easy to use, and VERY WELL constructed.
Nice review , thank's .
I'm looking for new pad's for my PC and my Makita , but just want the velcro backed version's. I don't want to buy the quick change system. It seem's like it's un needed , but I will check into it further before I make my decesion.
I'll start out with the PC pad's first and see how it goes from there.
Where's a good place to purchase ??
The Edge2000 system works for the PC as well as the rotary buffers. There are many advantages to the system including cost but this thread is not spam so I will not elaborate however I hope you will read other reviews of the system for the PC before making your decision that the system is un-needed.
Thanks for a great review mgm,
Aaron
As for centering your average flexible velcro backing plate and pad, is it really that difficult? I don't have one yet, and I'm in the process of deciding which pads to use. The one thing I don't like about the Edge 2K system is the fact that you have to use their pads. So I guess my main question is just if centering takes time and is a pain or isn't it?
Carl
Fallguy & zainoshine ... Two of the biggest advantages to the Edge 2000 system is the ability to switch from the PC to the rotary with the same pad and the pad is centered perfectly each time with this system.
Centering on the rotary is fairly critical and on a velcro system can be a pain sometimes.
I have purchased the Edge pads from www.premiumautocare.com ... they are a sponser of this site ... you will get great customer service from them as well as from Aaron at Dedication to Detail (Edge)
One more thought ... I have had some problems with the velcro systems in that the velcro backing plates lose their ability to hold the pads.
Both systems have their advantages though.
Just my .02
I'm curious about the Edge 2000 pads. I like the looks of the Rotary pads, but not the PC pads. Is there any reason not to use the Rotary pads on a PC?
Regards,
Dan.
The only problem with using the rotary pads on the PC is that they are really bigger than what the PC is designed for. A slightly better alternative is to buy pads for the PC and use them on the rotary ... unless you use the rotary a lot, then it would be better to have specific pads for each machine.
Just my .02
Just my .02
Hmmm... Well it's a bit hard to see the PC pads, but they look like fat lumps. The Rotary pads look more like my LC 7.5" pads (which I like). I'm not sure how well the PC pads would work in tight places.
Thanks and regards,
Dan.
I have the edge 2000 pads for both the rotary and PC.
The double sided rotary pads aren't as meaty as the PC pads, but I haven't experienced any performance/durability issues with either type. Maybe Aaron can jump in for some insight.
For me, it's a big advantage to have your pad dead on center each and every time. When you're off center it will affect the balance/feel of your machine. Try running your PC at 5-6 for an hour or so and you'll notice so brands of pads will wear an edge around the velcro, which leads to early pad failure.
I'm not trying to run a commercial for Aaron, but I think his pads perform and hold up as well (or better) than any other make on the market. The only downside that I see on the PC, is there's still a little tweeking left to correct the vibration caused by the quick attach.
It looks like using these pads wouldn't be a problem, but I can imagine the cleaning and drying would be more of an issue. You can't wring them dry and I would imagine the coupler in the center would prevent running it through a chamois wringer. So on a PC you would just have to wait a long time for them to dry.
Actually they dry out very quickly. Here's what I do:
1) Soak/Wash in Woolite & warm water. Rinse out with warm water.
2) Wrap them in a clean cotton towel and squeeze out the water.
3) Attach them to the PC or Rotary to sling off the remaining water. Don't have the pad facing you, your car, etc.. unless you want to be covered in water sling!
4) Place them on a clean towel on top of the dryer while I wash my MF's. Next morning they are 100% dry.
5) Store them in their packaging baggy.
-The instructions also mention not to stack anything on top of the pads. I assume this will cause the pads to crease.
If this helps anyone out, I've decided for now at least, LC 7.5" pads work best on the rotary and the Edge 6" 2k pads work best on the PC. In my experience, the PC really seems to beat up velcro. My 2 cents.
(DISCLAIMER: I have only been using the LC for a cople hours on the rotary. I reserve the right to change my mind about if I like them or not at any time :cool)
I have tried Edge 6" and 8" 2k pads and LC 7.5 pads.
Thanks and regards,
Dan.
The PC pads actually have a good shape to them ... the pictures I have seen really distort the pads.
BTW ... I have had velcro issues in the past too, but I use my PC at speeds of 5-6 a lot. IT seems like the velcro backing pad just wears out.
I just got done reading about the edge 2000 pads care and use from their website and the website says never exceed 2500 RPM?
Are some people using these with the PC on a setting of 3-5 which is above 2,500 OPM? I thought a speed setting of 1 on the PC is 2,500 OPM? Did you notice anything unusual with the pad at these speeds?
Is OPM different the RPM??
Actually the PC is measured in OPM or Oscillations (back and forth motion) per Minute.
The pad hardly spins (RPM) or Rotations per Minute .
I realize this, however, wouldn't there be a limitation, and I'm just asking to learn something that we might need to know regarding these pads too. I just would have thought since they have a limitation of RPM's, is there a limit with OPM's? Or there is no reason to take into account OPM's?
The two should be the same. The Osillations are produced by the mounting area being off-set on the shaft of the PC. In the case of the PC the off-set is approximately 1/4 inch. So when the shaft spins the pad actually moves back and forth rather than spinning because it is mounted into a bearing that allows it to move in a random pattern. Sometimes spinning slightly and sometimes staying still. I think the reason to not exceed 2500 RPM is because of the heat that would be generated by friction and the centrifical force that could build up within the pad which could cause it to come apart.
This question could probably be better answered by Aaron (Edge)
I am not trying to confuse things but this is my understanding of how it works.
Sorry to go on and on and on
Not at all and I appreciate your response. I really the education of things too! And that is I why I ask, believe me, if you follow me here on this board, I'm not afraid to ask...you know what they say..."The worst question is the one never asked" :)
That speed is a rotary speed only. It means rotations per minute not oscillations. We do not have a speed limit on the DA pads at this time, however on the 2000 system the pads feel best below speed 5
