dsms + AutoConcierge: Rolls Royce Phantom Drophead Coupe
dsms
Initial condition...
The car had quite a few bird bombs, we were lucky enough to get to them before the etched the film as the entire car was wrapped by Premier
Car was in surprisingly dirty condition. I started on the wheels and Bob wash the paint and rag top.
P & S brake buster and a mixture of brushes did the trick... btw RR's have floating center caps that never move, even when the car is speeding down the road, as if driving a drophead isnt "pimp" enough need not your centercaps rotate an inch.
Before shot
After shot, wheel wells were cleaned with enviroclean. Not much to do in there as they were carpet/felt lined at all 4 corners.
Bob hadnling the rag top...
Not Bob handling the paint...
Under the hood, before
During
After
Before we started correction on the car, the aluminum hood needed some attention. As expected it faded a bit, Bob had a good combo for me to try and it worked very well (I will let him elaborate on it if he wants, we all have our secrets)
I started by hand and made some good headway but it took a while...
50/50 (left side uncorrected, right side polished)
We decided to machine it out instead so we pulled the car in and got to work, the Festool DA with a red finishing pad
Bob handled the several bird etchings in the clear film with a heat gun, as he explained before about 360 degress, 2inches or so off the finish and left it on for no more than 4 or 5 seconds before letting it cool. Most times this process needs to be repeated several times to lift the etch on film
All gone
Correction was a 2 step process: extra care was taken on the film. Low speed polishing with a well moistened pad on a DA is the way to go
Festool DA
Menzerna 106FA w/ finish pad
Menzerna 85rd w/ finish pad
Me with the Festool
Bob cleaned and conditioned the leather.... all 17 cows worth of it :tongue:. After the first go with the conditioner he decided the leather was soft but not as soft as it should be. He went back a second time with the conditioner and the leather softened up a bit more and had a supple feel, dry to the touch.
The interior piano black wood seemed to be perfect until we checked it with the LED. Strangely enough some sanding marks were found. Bob began hand polishing and with no luck he ended up rotary correction the wood finish with a 3" pad and BP at about 900rpm using slow passes.
The end result of machine polished wood under the LED...
Finished off and topped with CG acrylic glaze
Some sun shots of the paint... no LSP
The LSP of choice was CG acrylic glaze and JetSeal. Bob machined in the acrylic with the festool and buffed it off right away. He followed up with 2 coats of Jetseal cured 30minutes each and buffed off with some DI water.
Waiting for JS to cure he tidied up the engine bay, cleaning the jambs and dressing all the trim
After...
Some finishing tocuhes included polishing the glass, umbrellas and the wheels.
The final wipedown
Final shots
[/B]
The boat deck
Wheels were hand polished, sealed and tires dressed for a matte finish
Wood trim in sunlight
And a walk around video in the sun...
Thanks for looking, this was a fun car to work on!
What an unbelievable car!
Perhaps "car" is not good appropriate at all... Chariot?
Ahh... yes. ROLLER.
Oh my, love the interior and all.
Well, I would like to see something a little different in the wheel department, but sometimes in person they just look "right".
You guys look like the U.S. Olympic Detailing Team or something. Super pro gear and presentation. PRIDE.
Nice job. :bow
Great job...I've seen those floating hubcaps at freeway speeds before. It's pretty trippy the first time you see it and it's definitely pimp.
I'm so confused...dsms...I thought you were out for a visit and were "job shadowing", but it's been weeks now, hasn't it? And I don't get it...are you saying that the Roller has some sort of clear (plastic, clear bra?) kind of film on the whole thing that gets etched and you take the etching out with a heat gun?
Dave went home weeks ago,but is busy with his own business and put the write up here in his own time frame. No "shadowing" we split the cars we worked on together in half, so everything I did he did and vice versa.
The Rolls Royce has Venture film applied to the entire car, and this particular client has done this to three of his cars because he wants ultimate protection. The heat gun step is a very delicate operation and one wrong move and the film can be ruined, and yes this is one of the correction options available to fix issues with clear film.
toyotaguy said:
any close ups of the bird "etching" and the heat gun process...looks interesting
Bob's process might be a bit different, but I've done this quite a few times now (learned the "trick" from my Venture installer); it works very well on scratches/etchings on clear bras, but like Bob said you have to be very, very careful. When I do it I spray a little Plexus, heat, plexus, heat, plexus, heat... If you know a venture installer just have him give you a piece, put it on a scrap panel and experiment.
On topic: Nice work. :) I love that car.
Fantastic job on the Rolls. The car seemed to need a surprising amount of correction for such an exclusive brand.
Wow... even Bob looked like a real-sized person next to that monster! :) Nice job guys and thanks for the tip on the film! I've got some film in my shed that I'll apply to the neighbor's cat soon and try the heat gun thing out!
that's another level... I'm with Kevin on this one - you guys are like the Olympic Team out there. Fantastic work guys!
bufferbarry said:
You guys almost look like a father and son team. Another terrific job.
Nice Barry.................. pointing out the oldness for all to see, next to the "Golden J" everyone looks oldddddddd:chuckle:.
yeah bob I hear ya man! didn't mean for it to sound like that lmao. its funny you say old. I was working on 96 camaro the other day and I thought wow I remember when this thing came out. I notice a lot lately that I see these old dive cars that were once cool. I think it was one of the first time I began to think wow I have been at this a while now.!
