Dry Coat Guide
A guide coat is to indicate high and low spots in the body panels. Has nothing to do with "swirls", after all, the sanding process will remove those, and put deeper marks into the surface as it "evens" it.
Grumpy
Could the guide coat be used between sanding to highlight any missed areas i.e. after sanding with 2000 grit to show any missed areas from 1000 grit
