Do anyone use Menzerna Intensive Polish PO 91E
Old Pirate
AMG Classic Car Detailing
I'm being noticing that very few folks are using 91E. I'm wonder if it's worth having or just stay with SIP? Any information from anyone who uses this product would be great..........Thanks................................................Angelo
I haven't used it, but was planning on picking some up soon. I do have SIP, but others have mentioned that IP works better on softer paint.
Thanks shine!
slicknickis3 said:
I use IP quite often. I find it easier to use on softer paints than SIP. I just wish it didn't dust as much...
Thanks for the information slick! I think i will not put any dinero on this product yet.
Still using this product. So far in my experience with polishing it hasn't failed me yet. I haven't done a ceraiclear yet so remains to be seen :)
I have a bottle of Intensive Polish. It is the least favorite of my polishes. The clear coat on my cars ranges from fairly hard to very hard, and IP just doesn't seem to do much for me. As others have said, it is probably useful on softer paints.
it's the only Menzerna I've used for 1st stage, then I have Final Polish as well. I thought it worked well. Dusty and gets finicky with higher humidity but it worked well. had a tough time with it on a newer Cadillac but it worked very well on a 07 lexus.
I won't order it again as it seems SIP is a better choice in the Menzerna lineup.
blk45 said:
I've got it Angelo. I'll give you some to try.
Thanks blk45, will call you soon!
Thanks eyezack!
Thank you Joel!
Thanks dub for the information!
Thank you everyone!:up
Very true! Im in FL and there are some days I wont even use it bc its damn near impossible! I might have to give this SIP a try...although i have been reading alot of good reviews on M105...which should I go with?!?:think2
M105 makes SIP seem like a light-medium cut polish--M105 is definitely a heavy hitter with much less working time than SIP. M95 cuts like M105 but with a longer working time.
Oh, have to put this input in. Prima Swirl cuts more than IP and finishes down LSP ready on Jet Black, which is super soft BMW paint. That could be another alternative if you want. I just prefer the slow and steady route thats all :)
I have also heard that Prima Swirl is a superb polish. Give it a try.
I'd consider SIP a medium polish as well. 3m 300 RC cuts better than SIP as well.
Thanks Shine!
Thank you eyezack might have to get some to try out.
Thank you porta
Cool thanks wannafbody!
