Dilution ratios of ONR
Kevinch
For those of you using ONR for more than just a car wash; would you lend a little advice?
I've been searching for a few hours this morning (using the search engine & just cruising the site), but I'm having difficulty finding posts on how to dilute ONR to use it as a QD, APC for interiors, glass cleaner, etc.
Based on the (mostly) positive reviews here, I've received my first purchase of ONR & I'd like to mix up a few dilutions to try it out. I know that the manufacturer's recommendations are 1oz to 2 gallons water for washing & 2oz to 1 gallon water for claying, but beyond that I'm not sure.
Thanks....
8 ozs. per gallon for QD.
Thanks....
1:16 (8 oz per gallon) for QD
1:64 (2 oz per gallon) for clay lube
1:256 (1 oz for 2 gallons) for rinseless wash
1:512 (1 oz for 4 gallons) as a water softener
I use it at QD dilution when I've used it for interiors, but that was mainly because it was what I had mixed up at the time. I also sometimes use it at 1:32 as a pre-spray prior to a rinseless wash, if the car is a bit dirtier than usual.
