Hi, I am trying to correct light swirl marks on a white 2015 Macan using Zaino PC. I have a Dewalt cordless 5” random orbital and chemical guys hex pads (orange, white and black). Most random orbitals use speed settings, 1,2,3 etc. The Dewalt uses rpm, 2000-5500. Can someone recommend a speed setting in rpm for each pad? Also, should I need to use all of the pads? I would prefer a 1 pad, 1 product solution. I don’t expect it to be perfect. Any other tips and suggestions are appreciated.
Redknight9 - Welcome to the Forum !
Porsche paint is pretty medium to hard paint in in my experiences with it..
I know nothing of your C/Guys pads, so no help with them.
What is your experience level in years using your Random Orbital ? This will help us better respond to your questions.. Thanks..
Have used Zaino Fusion PC when it first came out over a decade+ ago and it was ok, but there are better products out there..
For any Random Orbital to work good, it needs Pad Rotation - the more the better -
If I had to use a Random Orbital, I would want to run it up as fast as it would go to get the most pad rotation to remove defects, and then slow it down to further refine the spot you are working on..
I also like to keep the pad a little moist so it will not dry up too soon.. I like to work the correcting/finishing/product down to nothing, and always get excellent results..
If all you have is 3 pads, that will not ever be enough if you are planning to going over your entire vehicle...
For example, I use only Rotary Power, and I might use 10-12 pads to completely correct a Cayenne that is pretty scratched up from the "brush&swirl" car wash..
If your C/Guys pads are Orange = heavy correcting, White = mild correcting, Black = Refining/Finishing pads, then you want to start with Orange, and your Zaino Fusion PC, squirt a little Zaino Z6 or something like distilled water on the pad to get it just "moist", and then work the spot until the product goes away..
You are creating a little heat, so I like to keep the working surface and pad just " moist " enough, so that all the product is completely or almost completely gone, and then wipe off carefully with a clean microfiber, look at the spot, and see if you need to repeat the process..
In my experiences, I have found that allowing a product to dry to dust on the paintwork is not useful, creates a lot of dust that goes everywhere that needs to be removed, and makes for more steps/time to complete the correction on that spot of the panel..
You are going to need a foam pad cleaner as well.. Pads become dirty and clogged up, and then are useless and have to be changed to another one..
Here is the one I have used for decades+ and it always works great and is easy to rinse out..
https://www.autopia-carcare.com/snappy-clean-powder.html#.X-KHO1WQH3g
Foam pads may need 24 hours or more to dry out once they are cleaned and rinsed out... Put them on their edge standing up with air space between them to dry them out faster..
Good luck with this !
Merry Christmas !
Dan F
