Concrete Removal
ajnavo61490
AJ Auto Detail, LLC
I got a call this morning from a guy with a Silverado and has a little concrete splatter on his truck. He wants it removed and polished afterwards. What's the safest & easiest way to remove concrete?
Use a sponge soaked in distilled white vinegar to soak the cement. It will dissolve it so you can hose it off. If it has been on there a while, you may need to do a bit of polishing to remove minor etching in the clear.
i recently did a black F150 with the same problem...
took a sonus claybar to the whole truck and the cement spots came off no problem..
only problem was I went through an entire bar because it would scratch the paint, but M105 and an orange pad easily took care of the scratching...
i agree. works for me.:secret
very nice, thanks alot!
anyone have any experience with this method?
ajnavo61490 said:
has anyone ever tried this product? good product or too good to be true?
Even if it works, so does vinegar. Why spend $15 for a solution when you can get it for a couple bucks at your local grocery store?
