fordf150 said:Just ordered a tin of 476. Have never used this product before and will be using it as my winter wax. Any tips, tricks to applying/removing this wax?
autoaesthetica said:Accum will sign in on this. I think he likes to top 845(its liquid little bro) ..
476 is awesome, there are a couple ways to approach it. I tend to do the 2+2 of applying THIN, THIN, THIN, THIN, THIN, to one panel, then another, returning then to the first to remove and so on..
I have in the past on prepped paint done an entire vehicle and removed just as easily. The biggest issue is with it going on way too thick and you spending a good 3 months removing it. I personally prefer a whole car apply and remove.
tom p. said:Yeah, don't leave that stuff sitting too long or you'll need a grinding wheel to remove it.
specv said:You can use a DA such as a Porter Cable to buff this in; however for the work involved it is not worth it. I have tried this a few times using a final finish pad such as the megs finesse foam pad, LC red pad, etc. The trick is to heat the can just enough to loosen the stuff up, then you take a putty knife and scrape it out. Then, you put the paste on the pad and buff it in. If done properly you get the real thin coat you need, but again a foam applicator that is damp is much faster (JMO). 476 website has application suggestions and methods as well here is the tech sheet should you care http://www.collinite.com/assets/Uploads/Product-Tech-Sheets-PDF/TTech476pdf.pdf Since it is a pure wax it does well as a top coat over M07 (Show Car Glaze). I work one panel or two at a time. Finger swipe is somewhat applicable to this product. Hope this helps.
specv said:Since it is a pure wax it does well as a top coat over M07 (Show Car Glaze).
babalu said:Loooong time lurker with a question. I was planning to do KAIO and then 476, but will the solvents in 476 strip/react/not be ideal with KAIO?
specv said:The stuff can dry quick on a hot day with direct light...If you let this product dry it will be a royal PIA to remove and it will streak. Save yourself the headache follow the others advice, by hand, damp applicator, one panel, wipe and go..
